LEDmarkers V1 Dual ring LED tails (showcase)
Old Mar 28, 2011 | 10:08 PM
WhosUrBuddiee's Avatar
You have anything for G37 coupe???
Old Mar 28, 2011 | 10:40 PM
LEDmarkers's Avatar
Yes we offer tail shroud painting ,custom LED work ,hp LED reverse etc . We dont have any predesigned tail retrofits for the 37 but we can do almost whatever custom job you can think up .
Old Mar 28, 2011 | 10:41 PM
LEDmarkers's Avatar
Originally Posted by same olg
Bump for some sick tails, I couldn't get over to you tonight I was busy but I'll let you know as soon as I get a chance.
No prob mike .Whenever your ready
Old Apr 10, 2011 | 09:52 AM
TNC 718's Avatar
Check your PM?
Old Apr 12, 2011 | 09:24 AM
w4kj4k's Avatar
Just wondering, do you have any videos of these lights on a actual car? They look nice, but im curious how they look lit up on a car compared to the OEM's.
Thanks!
Old Apr 12, 2011 | 09:42 AM
djfarhan's Avatar
^ https://g35driver.com/forums/interio...ip-shroud.html
Old Apr 12, 2011 | 04:35 PM
w4kj4k's Avatar
Well i was curious about how the V1 looked, since he only offers these now. Thanks though!
Old Apr 12, 2011 | 05:48 PM
LEDmarkers's Avatar
I dont have any videos installed just pics compared to OEM on the site . We ship most stuff out so we dont get the chance to take a installed video . When we get the chance i am gonna build a set for my G and ill take some vids . IMO and most others the V1's look the best installed . These tails really transform the rear end even more than body kits . We have done 4 sets in the last 3 weeks and 3 more in the works so someone should post a video .
Old Apr 12, 2011 | 08:29 PM
w4kj4k's Avatar
Yeh the V1's are really starting to grow on me since its totally different, i just would love a video of real time on a car or something before i hop on it
Old Apr 12, 2011 | 11:18 PM
lilindienplaya's Avatar
why is the power side so complicated on these?
Old Apr 13, 2011 | 12:33 AM
LEDmarkers's Avatar
It needs to be able to control tri function through pwm + regulation with build in switching circuit . We design and make these modules to do this . These are not able to be made by the Diy'er . Pcbs are a very intricate design and use lots of small smd components . Its a major upgrade from the factory current resistor-ed power board . The modules in there are more like that on a buggati and cars that use PWM'ed tails .
Old Apr 13, 2011 | 08:52 AM
oh im aware of what all the components do and all i was just in shock that someone took the time to design such a product, hopefully you sell a lot of these units to make up for the time you put into making a setup this badass and beefy
Old Apr 18, 2011 | 06:28 PM
MidnightG35X's Avatar
Since you already have PWM controlling your brightness, one feature you could consider adding is pressure sensitive brake lights. A simple slide pot connected near the brake pedal controlling your PWM input then connected to the brake LED's. It was something I was going to do before I moved on to other things.
Nice work on the rest of the stuff.
Old Apr 18, 2011 | 07:12 PM
LEDmarkers's Avatar
Not really a fan of adaptive brake lighting for a couple of reasons . one being that the tails go full brightness anytime on the brake so its pretty much always as visible as possible is somthing i like .2 adaptive brake lighting wont be noticed by most drivers on the road . 3 It will no longer be plug n play and people would have to run wires through the car and install the pad and module . If it was possible to add a extra LED array to the tails for "fast braking " it would maybe work a little better but thats not possible and dont fit the design . Just because its possible to do doesn't always mean it should be done . Thats just the way i feel about it .
Old May 25, 2011 | 03:18 PM
  #30
pvdg35's Avatar
v1 is nice,...i was hoping i can find some V2 rings. i prefer the OEM ring and in search of the same numbers of LED (12) but smaller so i can try something out. there's gotta be a way to get those v2 rings w/o having to get a set of tails.
