LED Interior Lighting question...
Old Apr 6, 2011 | 02:17 AM
P3_Super_Bee's Avatar
OK, I changed out my interior lights for LED... Though there seems to be a problem. Was wondering if anyone else has seen this.
I have a 04 sedan. I replaced the "Map lights", The "Rear side personal lights", and the "Step/courtesy lights" I will have to say they look great!!! Here's the problem...
The "Map Lights" glow (not fully on, can barely see them) when the "door" is selected on the switch. If I switch the switch to OFF they are off. But with the doors closed, and the switch in "DOOR" they should also be off. All doors were shut, and if I put the old school bulbs back in, the lights work as advertised.
Has anyone seen this? Know a fix? Kind of lame to have to manually switch the lights on and off.
Old Apr 6, 2011 | 01:55 PM
Well don't actually know what the issue was, somehow I fixed it today. For most part all I did was remove the cover, push the ON/OFF switch a few times, and they quite "glowing". Now working as advertised.
Old Apr 7, 2011 | 02:28 AM
Well maybe not. Still have the problem. Anyone with any suggestions?
Old Apr 7, 2011 | 02:32 AM
sTeadFasT96's Avatar
Because LEDs use so little wattage that even if you don't have them "on" they will still barely glow. It's normal so don't sweat it.
Old Apr 8, 2011 | 02:36 AM
Got a reply back from iJDMtoy dot com, where I bought them.
They say:
Originally Posted by iJDMtoy.com
There is a simple fix however, you can go to your local Radioshack and purchase a set of load resistors and tap them to your lights.
You will need a 1/8W 10kW Ohm resistor, you will just need to tap it from the positive to the negative portion of the bulb. That should fix the problem.
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
RA081024
Aug 18, 2015 07:03 AM
Jadenkid22
Jul 14, 2015 12:33 AM
