05 coupe HID question
Hey guys I got an 05 coupe with the stock oem headlights/ HID's I want to swamp them out for brighter lights like 6k, what do I need to know and what do I need to purchase to make this happen do you need new ballasts or just bulbs? Thanks guys
yup im having the same problem.. idk how to install them.. i already order hids and i dont no who to wire that **** up i really dont want to cut any wires.. and the bulbs that came with the hids fit on the oem connecter but they wont stay on.... its pissing me off already....
Please use the search function as this has been discussed many times, but I'll lay down some knowledge.
First of all, 6,000k bulbs are actually dimmer than factory. There is a reason why 4300k is factory because it has the most lumens and our eyes don't pick up the bluer color lights as easily and also they suck in the rain as it just reflects off of the road.
Second, all you need are just the bulbs. Because our factory system comes with HIDs to begin with, all you need is a D2R bulb (because you're 2005 with reflector lights and not 2006+ with projector lights) in 6,000k and just replace that.
xxbigluxx, it's as simple as just replacing the bulbs. You don't need to wire anything. If you've bought the proper bulb sockets, everything should go fine as it should fit the socket type perfectly and the factory igniter should lock properly onto the bulb.
I was just being nice, but guys, please use the search function. There is information EVERYWHERE.
lol hey man thanks alot i haven been using the search but i cant find ****.....that why i was getting pissed...but i have d2r bulbs that came with the aftermarket hid kit and i installed the bulbs and the bulbs turn on and flicker and turn off ... then the factory bulbs work perfectly .. thats what i was getting pissed......alll so i want to put hids on my fogs how do i go by that.. welll.. ima keep searching....its my first g35...and its ****in hottt..
