DIY: G35 Sedan HID and HID Fog Installation
Old Nov 19, 2012 | 02:35 PM
G350RT's Avatar
Question so when the HID are installed on the fogs lights will it interfere with the stock HID?? Like will there be any major electrical issue because both HID are running and they are drawing alot of wattage??
Also have any one had any problems with DDM Tunnng Ballast i had a DDM Tunning kit before and had it in my civic ( Back when i had one) and it totally fried my fuse box has any one had this happen?? Does that mean my Ballast is bad?? And what if still works if i test it should i re-use the ballast. Cause the civic head lights are the same bulb size as Our G35 fog lights. Also is there any fuses or relay we can put in between the wires just in case like and electrical surge happens??? Any thoughts???
Old Nov 19, 2012 | 02:38 PM
DVG's Avatar
DVG
Use a relay and you wont have to worry about the wattage. I use DDM almost exclusively now. What do you mean it fried your whole fuse box? WTF? It should have fried only 1 fuse...
Old Nov 19, 2012 | 04:59 PM
G350RT's Avatar
I had a 99 ek civic coupe and near the battery was a fuse box that had the batter cables running into it to power the other electrical components in the car and that box like melt fuses and one of the cables the negative one that ran from the battery to the fuse box melted through the plastic housing of the fuse box. Yeah so i dont know it there will be and electrical interference with both HID running. And when you say relay where would i put that relay and what kind of relay would I use??
Old Nov 19, 2012 | 05:04 PM
DVG's Avatar
DVG
Ermmm something was wrong there, fuses werent doing their job if they allowed wires to melt. You didnt put higher amp fuses in did you?
I have 2 HID kits in my mazda, no problems there.
This is the harness Ive been using: http://www.ebay.ca/itm/180736723307?...ht_2203wt_1111
I would recommend getting someone else to do it this time. You dont want the same thing happening to your G.
Old Nov 19, 2012 | 07:41 PM
NFSP G35's Avatar
? = 2B || !2B
So hard not to make Honda jokes right now
Old Nov 19, 2012 | 07:43 PM
DVG's Avatar
DVG
The engineers know how to keep wires from melting lol. It was clearly something the owner did
Old Nov 19, 2012 | 07:50 PM
NFSP G35's Avatar
? = 2B || !2B
Oh, no doubt... But it just begs for one of those: "well there's your problem..." posts
Old Nov 20, 2012 | 05:33 PM
G350RT's Avatar
Actually it really wasn't because the HID were working for 6 months before this incident happen so you should talk what u know if you dont which clearly you dont you should shut up.
Old Nov 20, 2012 | 05:36 PM
NFSP G35's Avatar
? = 2B || !2B
I'm not sure who you're talking to.
Also, use commas.
Old Nov 20, 2012 | 05:37 PM
DVG's Avatar
DVG
shut up.
1. The OP is very well written and easy to follow.
2. Your questions are poorly formed and give useless information, if you have a question, state it and throw in some punctuation and proper spelling.
3. I bolded the things you wrote that show you dont know what you are talking about, I was trying to help, but **** it, maybe you will find a way to melt your G35s wiring too.
Old Mar 3, 2013 | 07:48 PM
MikeJones916's Avatar
Great write up
Excellent write up.
I will be following this next weekend when I install my new Morimoto bulbs.
Great pics too btw!
_Michael
Old Mar 25, 2013 | 03:56 PM
Droopy89's Avatar
Figured id throw this in there, the 03-04 are shaped quite differently in the fog part of the housing, this wont work on them. Hope this saves someone some time and effort.
Jusseth
Sep 13, 2020 12:25 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
attarday
Jul 15, 2015 04:03 PM
