Headlight Troubles...please help
Old Jul 17, 2011 | 11:53 AM
dev1983's Avatar
Lightbulb Headlight Troubles...please help
I'm having issues with my headlights (just started) and can't seem to figure it out. I have an 03 with 06 projectors and aftermarket bulbs. When I turn on the headlights (HID) only left side may turn on, if I turn it back off then on, maybe the right side may turn on, or neither, its a crapshoot to get both on..haha. I've had these projectors and bulb in for about 3 years now, I don't think its the bulbs. I searched, it maybe the ballasts? connections? Fuse? Don't know where to look...any suggestions?..Thanks
Old Jul 17, 2011 | 04:09 PM
dev1983's Avatar
the turn signals still work...
Old Jul 18, 2011 | 07:38 AM
dev1983's Avatar
Anybody?
Old Jul 19, 2011 | 09:08 AM
clutchless's Avatar
I doubt both ballasts and would go at once and act with your symptoms. It has to be something common to both headlights. If a fuse, then they would never work. Since it is intermittent, I would look into a bad relay, bad headlight switch or loose wires somewhere. First check that the connections are good at both headlights. You may need a shop to electrically test the headlight switch and connections.
Old Jul 19, 2011 | 09:24 AM
dev1983's Avatar
Ya that what I was thinking too. I'll take a look at it this weekend since I have to take the bumper off..such a pia.
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
