FX-R retrofit into 2006 sedan
Old Dec 12, 2011 | 10:06 PM
MotF Bane's Avatar
As you all know, the sedan doesn't get that nice easy setup the coupe does, and to make it more difficult on myself, I chose to put the FX-R's into the top, preserving the H4 halogens in the lower bay. The G37-R shrouds I purchased went totally unused, due to space constraints; I kept the factory ballasts. Bulbs are 85122+. The project took parts of four days, totaling around 30 hours.
Before, low beams, about 50 feet, through the windshield.
Final bracket design, right headlight.
Reflector cut to fit, left headlight.
Bezel just before cutting, left headlight.
They're hard to see, but there are two small acrylic wings attached to the projector at left and right, painted metallic silver. These hide the screws, brackets, and back of the capsule from easy viewing at the front.
An overhead view of the right headlight. No shroud looks fine IMO, because the FX-R lens has a chrome ring.
Cutoff, about fifty feet, same lot as before. The lot is not perfectly level, so don't mind the slope. Picture taken from alongside the left front fender.
Same as above picture, except picture taken at 6-8 feet.
High beams. FX-R at high, plus the H4 bulbs at high.
Old Dec 14, 2011 | 05:22 PM
IvoryGT's Avatar
Nice work, no shroud tho?
Old Dec 14, 2011 | 08:33 PM
MotF Bane's Avatar
I couldn't figure out a way to fit one in there, there's so little space above and below the projector.
Old Dec 27, 2011 | 07:56 PM
IvoryGT's Avatar
I know it's scary but you'd have to cut into the stock housing and flush mount it.
Old Dec 31, 2011 | 02:47 PM
KB24MVP's Avatar
Awesome work. Came out great!I have a pair of tsx projectors laying around. Does anybody offer retrofit services on this forum?
Old Feb 3, 2012 | 08:57 PM
SAMzG35's Avatar
G35
your inbox is full
Old Feb 9, 2012 | 03:09 AM
guitarrocker98's Avatar
They look FANTASTIC!!!! Its funny on other forums they use G35 projectors for better light, but here we use FXR. Just interesting.
Old Feb 10, 2012 | 08:42 PM
IvoryGT's Avatar
The two projectors have virtually same optics. Unless it's a G37 projector with better reflective bowl design. The output are the same for the G35 and FX (R)
Old Feb 10, 2012 | 11:22 PM
Wait, so if the output for the G35 and the FX (R) are basically the same then what is the point of doing the retro fit? Might be a stupid question, but I am fairly new here.
Old Feb 10, 2012 | 11:57 PM
CandlestickPark's Avatar
ill Sedan
He did this retrofit because 03-06 Sedans don't come with OEM projectors.
Old Feb 11, 2012 | 02:06 AM
Okay that makes complete sense. I just assumed all G35's came with the projectors, and when they said they are basically the same as G35 projectors I got thrown off.
Old Feb 11, 2012 | 11:39 AM
ill Sedan
Nah, Sedans got screwed on all kinds of stuff that Coupes got....LOL
Old Feb 11, 2012 | 01:17 PM
Seriously!!!!!! Well none the less I give props to you MotF Bane!!!! Well done on the projectors. I have installed a set and I have botched a few install jobs on them as well. WELL DONE!!!!
Old Feb 11, 2012 | 01:24 PM
G35Papa's Avatar
^ Marcus speaks troof!
Retrofit came out great. A shroud would add that final touch of completness but those don't look to bad as is either.
Jusseth
Sep 13, 2020 12:25 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
itgogitrev
Lights
May 2, 2016 06:53 AM
TreeFiddy
Aug 10, 2015 06:50 PM
