LED Strip. Help a Noob
Old Jan 25, 2012 | 05:28 AM
UsNguyenAF's Avatar
I just order some LED strip trying to install. I want them to turn on when i start the engine and turn off when its off. Where should i tap it into? i would think the side marker lights would be good but i didnt want to do it and **** something up. Can someone tell me what would be the best and most simple way.
Old Feb 1, 2012 | 01:29 AM
GarageLife's Avatar
I don't think the side markers come on unless the lights are on... You'll want to wire them to something that comes on with ignition. Get a test light.
Old Feb 8, 2012 | 12:22 AM
SAMzG35's Avatar
G35
get the add a circuit and connect it to the fuse box along with a fuse, also you can use DRLs and tab into them i guess?
are you talking about clearance strips?
Old Feb 9, 2012 | 03:04 AM
guitarrocker98's Avatar
Cigarette lighter. Thats where I tapped those lights into.
Old Feb 9, 2012 | 03:38 PM
saywat?'s Avatar
led strips are the gays man dont do it
Old Feb 9, 2012 | 03:45 PM
SAMzG35's Avatar
G35
if they are going into the clearance strip they would look very good
Old Feb 9, 2012 | 07:17 PM
LED's are okay depending on what kind of LED's you use, color, location of them ETC.
Old Feb 14, 2012 | 09:58 PM
Mr. Samster's Avatar
just tap it into the cig lighter. You can also install a switch to turn them on and off when you like.
Old Feb 19, 2012 | 12:28 PM
UsNguyenAF's Avatar
Yeah i was gonna put them on and if i dont like it then i could always take them off.
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
g.spot
May 9, 2016 10:54 PM
NailBomb
Oct 28, 2015 07:53 AM
Gabe83714
Oct 6, 2015 06:40 AM
