h1 bulb died, aftermarket one doesn't fit
Old Apr 25, 2012 | 12:27 PM
wonton1017's Avatar
So I bought a few H1 5000k bulbs off eBay, I tried putting them in but they seem to be very loose compared to my OEM bulbs.
No lights either when car is started :S
Specific H1 bulbs I have to look for?
Thanks
Old Apr 25, 2012 | 02:52 PM
pythonjosh's Avatar
Check your fuses and make sure the bulbs are not blown and plugged in correctly.
Old Apr 25, 2012 | 07:00 PM
wonton1017's Avatar
I just tried my friend's bulbs and they work fine.
But these aftermarket ones literally fall out of the socket.
Old Apr 26, 2012 | 10:09 PM
saywat?'s Avatar
pics would help ur cause
Old Apr 30, 2012 | 08:42 PM
wonton1017's Avatar
Here is a pic of the aftermarket H1 bulb:
https://i.imgur.com/hjuOv.jpg
If i remember correctly, the OEM h1 bulb has a little slot at the bottom which I guess gives it a tighter fit.
Old Apr 30, 2012 | 08:48 PM
saywat?'s Avatar
usually theres a dimple u gotta match up to the slots on the housing. does it not have the dimples?
like this
Old Apr 30, 2012 | 08:50 PM
wonton1017's Avatar
Hmm, can you circle the "dimple"?
The one in front of me looks pretty much identical to the one you have linked.
Old Apr 30, 2012 | 08:51 PM
saywat?'s Avatar
maybe i met nipple but the raised round part u see in the pic
wonton1017's Avatar
Oh yes, it does have a "nipple" xD
Old Apr 30, 2012 | 08:55 PM
saywat?'s Avatar
usually that nipple plus the metal prongs in the back of the head light should lock it in place nice and tight if it doesnt maybe u bent the prongs while removing and u gotta bend it back to spec
Old Apr 30, 2012 | 08:58 PM
wonton1017's Avatar
thanks for your help, I will give it a try right now
Old Apr 30, 2012 | 11:36 PM
wonton1017's Avatar
So it worked, haha.
Ended up being the prongs not being able to completely lock the h1 bulb in because the h1 bulb kept slipping out by a little. So I used tape around it, doing this only to pass my vehicle inspection.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
whatacar
Canada
Aug 13, 2015 07:33 AM
EasySausage
Jul 20, 2015 03:56 PM
