Single reverse light out
Old Oct 4, 2012 | 12:04 AM
Canadiotica's Avatar
One of my reverse lights is out on my 05 g35x sedan. Ordered replacements and the right side still will not work-tested the bulb in the left side and it worked. Anyone know what may be the issue ? I don't think it could be the fuse or else both should be out but aren't. Unless there is a seperate fuse for left and right ? Can anyone chime in on what I should do?
I'm pretty sure the stealership will rape me!
Old Oct 22, 2012 | 03:11 PM
DVG's Avatar
DVG
I had this problem. The wire harness on the car was poorly designed. Check the wires wear they go into the trunk (the rubber gasket on the right)
Guarantee they are frayed.
Where in Canada are you? If youre in Ottawa I can help you.
cbax
Intake & Exhaust
11
Jul 15, 2023 12:43 AM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
yosip1115
Forced Induction
Jan 28, 2016 02:51 PM
attarday
Jul 15, 2015 04:03 PM
