Clearance Strip and Interior lights not working! HELP!
Old May 17, 2013 | 05:20 PM
mynameisname's Avatar
Unhappy Clearance Strip and Interior lights not working! HELP!
So I was installing an LED strip that takes 12V . I put them in the clearance strip and as soon as I plugged in the second LED strip I think it shorted. I also noticed that the interior lights of the A/C controls and Clock are out as well. Does anyone know how to fix this? And does anyone know how many volts the Clearance strip can take?
Old May 17, 2013 | 05:37 PM
saywat?'s Avatar
check fuse. i beleve its the box behind the battery
Old May 17, 2013 | 05:39 PM
I did check the fuses today but non of them look like they're blown. Do you know which fuse controls those lights?
Old May 17, 2013 | 05:40 PM
saywat?'s Avatar
check again
Old May 17, 2013 | 06:20 PM
check again
Just checked the fuses and tested them, they're all good.
Old May 17, 2013 | 06:26 PM
saywat?'s Avatar
even the fuse box hidden behind the battery?
Old May 17, 2013 | 06:27 PM
Yup checked both fuse boxes. I don't know what to do
Old May 17, 2013 | 06:28 PM
saywat?'s Avatar
idk then sorry
Old May 17, 2013 | 07:15 PM
guitarrocker98's Avatar
Fuses haha. That's my gut. I would actually pull all the fuses and check them individually. Hope you didn't short out your bcm.
Old May 17, 2013 | 07:21 PM
I really hope it's just fuses. I will recheck all the fuses on Saturday. Also, is every slot for the fuses supposed to be filled (I noticed no fuses were ever in the BCM fuse slot - in the fuse box next to the battery)? If the BCM shorted, wouldn't I have a problem with all my other lights too?
Old May 17, 2013 | 11:24 PM
So it's dark out here in Atlanta now and I noticed that my tail lights are also out which is a hazard. I did a little more searching and found this thread and I really hope this fuse solution works and that it's not the BCM. https://g35driver.com/forums/faq-diy...dont-work.html
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
newg37
Jul 26, 2015 09:32 AM
attarday
Jul 15, 2015 04:03 PM
Jadenkid22
Jul 14, 2015 12:33 AM
