Fog Light Replacement Bulbs?
Old Feb 17, 2005 | 01:03 PM
  #31
escobar929's Avatar
cool thank for the info
Old Feb 19, 2005 | 03:39 PM
  #32
vleo8181's Avatar
I looked at my headlight assembly and he cover says that the bulb should be an hb2. Is this the same as an h4?
Old Feb 19, 2005 | 06:35 PM
  #33
skeleton_cru's Avatar
Sedan
Yes, HB2 = H4
Old Feb 20, 2005 | 12:37 AM
  #34
IS300TOG35's Avatar
► Matt ◄
Hmm, I just got these cheap off ebay, but im confused with th 2x and 4x ****. The ones I got say they are 4x, which mean they are 100/90w. Will that be ok to put in or should I have gotten the 2x?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7955398214
Old Feb 20, 2005 | 04:29 AM
  #35
Sedan
Wrong wattage. You need 60/55 watts I believe.
Old Feb 26, 2005 | 09:35 AM
  #36
RichK's Avatar
SO the fog light bulbs are H4 and not H3? I just got rid of a 2003 Maxima and removed all my PIAA Extreme whites (hi beam and fogs) that matched the OEM HIDs. I thought the fogs were H3 and the high beams were 9005s. Any clarification here?
Old Feb 26, 2005 | 09:46 AM
  #37
Sedan
Fog/high bulbs = H4.
Old Feb 26, 2005 | 10:26 AM
  #38
MIA_G35's Avatar
Fogs are H4's. I finally ordered the PIAA Plasma Super GTX, which I also have as wedge bulbs in the clearance light and side marker. May go with a super white bulb later on, but I like the blueish purple look that Plasmas give off.
Old Feb 27, 2005 | 10:14 PM
  #39
BombRush's Avatar
Is it Illegal to Carry White wedge bulbs ?? DO you get pulled over by cops for having them in clear corner and clearance strip?
Old Feb 28, 2005 | 04:24 AM
  #40
Sedan
White clear corners = illegal.
White clearance strip = legal.
Old Feb 28, 2005 | 09:54 AM
  #41
BombRush's Avatar
What Can I order for white clearance strip??
Old Feb 28, 2005 | 08:55 PM
  #42
werd's Avatar
hmm.. the clearance strip thang... is that only for the coupes???? and is the H4 same for the sedans??? and what bulb do i buy for the clear corners... and what bulb are the signal bulbs... and if the sedan has clear clearance strip as well... what bulb do i buy??
thank you
Old Mar 1, 2005 | 01:45 AM
  #43
Sedan
Since I do not have a coupe I don't know what bulb is used for the clearance strip.
Old Mar 2, 2005 | 11:39 PM
  #44
Sedan
Your answer is in this thread:
https://g35driver.com/forums/showthr...nce+strip+bulb
I searched clearance strip bulb in the coupe forum. Give the search a try sometime.
Old Mar 8, 2005 | 09:39 PM
  #45
barrios35's Avatar
Thanks for all the info. now How do you make the fogs come on with without turning on the HID lights? Can it be done?
