can a Corroded battery cable cause headlights to fail?
Old Aug 17, 2013 | 04:37 PM
UR2EZ's Avatar
idk wtf is going on, hids went out, everything else still working. , changed bulbs, one ballast is new, swapped relay between high/fog, fixed corroded battery wire ( chopped off about an inch, used a new connector) still nothing. have a grounding kit so I was thinking of checking the headlight grounding connection, but I don't recall which one that is. I loosened and retightened the two that are on the far left and right of the bay, but I'm not sure if those are correct.
Thebaws11
Jul 2, 2021 11:36 AM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
SupermanGPS
Sep 19, 2015 01:42 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
