Halo wiring where best to tap for power?
Old Nov 25, 2014 | 11:16 AM
epborden's Avatar
I'm doing a projector retrofit and also adding in some halo rings out of personal preference. Would it be best to tap into the existing wiring harness for these or somewhere else? Secondly I unfortunately don't own a volt meter, so I have to ask which color wire in the harness (or otherwise) should I tap for power and ground?
Old Nov 25, 2014 | 11:32 AM
Urbanengineer's Avatar
Do you want them on always when the car is on? Tell us your preferences.
Old Nov 25, 2014 | 11:38 AM
epborden's Avatar
You know I didn't even think about this. I want them to come on automatically and when manually switched on with the low beams.
Old Nov 25, 2014 | 01:00 PM
What is the wattage on the angel eye you are considering putting in? This lets you know which you can tap into without burning the wires.
Old Nov 26, 2014 | 09:25 PM
epborden's Avatar
I haven't bought a pair yet, is there anything I should take into consideration? I did some searching and it doesn't look like the wattage is really listed for at least the kits/components I looked up.
Danielek
Oct 7, 2015 09:59 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
twentyeggs
Sep 11, 2015 03:58 PM
G35VSHNG37
Sep 10, 2015 01:54 PM
zcherub
Sep 10, 2015 12:03 PM
