HID lighting issues
Old Jan 19, 2016 | 01:18 AM
Rad510wagon's Avatar
HID lighting issues
Here's the situation. My daylight runner lights do not work. My right side Low beam HID worked after I changed my Orem ballast. It went out again and I switched over to 55w aftermarket HiD system. It was working fine, then it died again after coming home from the casino. So I have one light, parked, turned lights on/off and suddenly they worked. Turned it off again to try it and it did not work. Fuses were checked and all intact. Is it possible the column light switch go bad? I just need some direction on this because I'm trying to avoid a fix it ticket. Thank you in advance.
Calipat916
Jan 5, 2016 07:01 PM
DenZeL KnighT
Lighting
Dec 31, 2015 03:47 PM
mFinora
Dec 27, 2015 12:06 PM
TDL
Lighting
Dec 20, 2015 06:20 PM
