2004 Sedan - Headlights...
Yes they are and mine don't match either. I'm looking into changing to LED's and see if it's an improvement. The standard bulbs are 9003. I've also thought about seeing if I can come up with a modification to the outboard ends of the lower grilles and install a set of fogs there if I can find a set that will give it a factory appearance similar to a later g.
