New Led Pictures...
Old Sep 16, 2005 | 11:57 PM
Finiti35's Avatar
FGC South Florida BOD
Originally Posted by Jtrain
wtf is a dome light, and what size should we use
and whats a step light =P
Dome lights, or map lights in the G, are (you guessed it) the lights you turn on to read a map when it's dark. Step lights are (...you guessed again) the lights that light up as you open the doors to enter/exit the car... Both use a T-6 bulb I believe....
Old Sep 16, 2005 | 11:58 PM
pdjafari's Avatar
looks really good!!
gonna order some, is the 3022 also what we have in our tag/license plate lights?? I have already swapped my dome/door lights w/ piaa T-6 bulbs but these look much better and will prob. last longer...
Old Sep 17, 2005 | 12:14 AM
Psycraft's Avatar
the tag lights are regular 194 leds,i got the ones that have 6 leds pointing striaght down
Old Sep 17, 2005 | 12:22 AM
Psycraft's Avatar
ok heres one of the trunk "led" the picture totally doesnt do it justice..at all,it looks way nicer in person,and i couldnt get a good enough picture as well here it is..
Old Sep 17, 2005 | 12:37 AM
S-Tuned's Avatar
gtr proto test driver
hey psycraft how did you figure out how to change the step light?
Old Sep 17, 2005 | 03:03 AM
Psycraft's Avatar
i looked at it,its under the door..,you have to pry it out and the whole housing will come out..and then take the plstic clear cover off then changet the bulb
Old Sep 17, 2005 | 04:33 AM
mrjonang's Avatar
on autolumination.com, is this the correct size for the MAP LIGHT and the STEP LIGHT
31mm = 1-1/4" Long 6LED
1-1/4" LONG (31MM) X 3/4" (19MM) WIDE
Replaces: 3022 3021 3175 6428 6430
or are the map and step lights different?
Old Sep 17, 2005 | 07:43 AM
G35_coupe_6MT's Avatar
the one ive been wanting to change is the license plate one... Need to get me some leads for the corners anyway..
Old Sep 17, 2005 | 09:08 AM
PeteNJ's Avatar
Hey Psy,
Would you say the LEDs are brighter or as bright as the stock setup? From the pictures it looks as if they are much dimmer.
Old Sep 17, 2005 | 12:26 PM
Psycraft's Avatar
the leds are way!!! brighter and way nicer looking!! and yes "mrjonang" you are absolutly correct,those are the step lights 31mm 6led and the step lights are 31mm 4 led,warning though,the light is super fat,so just push the sucker right on...on the step lights that is..
Old Sep 17, 2005 | 04:04 PM
mrjonang's Avatar
Wait the steplights are both 31mm 6led and 31mm 4led?
Old Sep 17, 2005 | 04:49 PM
G35SHAWN's Avatar
Psycraft those LED bulbs definetly gave your ride's interior a unique touch. Good job ..btw which part of FL are you located?
-Shawn
Old Sep 17, 2005 | 05:09 PM
sage's Avatar
The lights bulbs for the clearance, clear corners, license plate, and trunk are all the same type; and the bulbs for the dome and for the side step are the same.
You can get the bulb type and all other info from the infiniti manual. the manual also shows how to change some of these bulbs...
Old Sep 18, 2005 | 05:32 AM
mrjonang's Avatar
K, thanks sage for clearning that up. Anyone here change there dome/map lights to blue? can you even see anything ? lol
Old Sep 19, 2005 | 01:48 AM
  #30
Sceptre's Avatar
psycraft - are these LED's straight up swaps? No resistors needed right?
