I need help with headlight/foglight install
Old Dec 25, 2005 | 03:02 AM
CarFanatic56's Avatar
I need some help taking out the stock headlights and fogs so I can replace them with some aftermarket, but I get stuck at after unscrewing off the caps....the pics show where I get stuck...
If anyone can help me...thatd be great!
Attached Thumbnails I need help with headlight/foglight install-headlight-g35-coupe-small-.jpg   I need help with headlight/foglight install-access-bulbs.jpg
Old Dec 25, 2005 | 03:07 AM
ablangc's Avatar
subscribe. I wanna know too!
Old Dec 25, 2005 | 04:47 AM
patman530's Avatar
the silver thing just twist counter clock wise and it should pop right out, for the fogs, there are clips that you will need to push in and then they will pop out, pretty standanrd for H4 setups
Old Dec 25, 2005 | 05:07 AM
Do you need to disconnect the battery when doin this? jus wondering
Old Dec 25, 2005 | 05:44 AM
avs007's Avatar
Out of curiousity, do the ones for D2S bulbs, like on the 06' lights, not twist on? When I put mine on, it didn't seem to twist on, so I just pushed it straight on. Is that what that notch was for on the D2R?
Old Dec 25, 2005 | 06:02 AM
patman530's Avatar
i'm not sure about disconnecting the battery, because i changed my bulbs when the housing was off of the car, but to be safe, you probably should, since HID involves high voltage.
when i upgraded my lights to 06, i twisted the d2s on the same way as from 05, when you twist it past a certain point, you hear a click and it snaps into place
Old Dec 25, 2005 | 10:35 AM
dR6's Avatar
dR6
Correct me if I'm wrong, but are the '06 fog lights a different size than the previous models? The manual said they were H1's so that's what I ordered. Everybody's been using H4's and it's making me a bit nervous..
Old Dec 25, 2005 | 11:52 AM
avs007's Avatar
Yeah, they are H1. H4 is for the ones that double as high-beams.
Old Dec 25, 2005 | 01:17 PM
GIIIV's Avatar
The D2R and the D2S both have a locking mechanism where you push in to engage the bulb's solenoid/connectors and twist to lock in the silver things to the bulb.
Old Dec 25, 2005 | 01:27 PM
Texasscout's Avatar
Thumbs up
I have an 05" sedan and if you are talking about the H-1/H-4 bulbs, there is a small wire clip with two ends sticking up. You need to squeeze them together and pull back and it will release the bulb.
Old Dec 25, 2005 | 03:19 PM
patman530's Avatar
2005 Fog/High beam = H4
2006 Fog = H1
Old Dec 25, 2005 | 09:32 PM
Texasscout's Avatar
2006 Fog = H1
H-1 = H-4 same-o, same-o
Old Dec 26, 2005 | 04:57 AM
avs007's Avatar
Ummm, H1 is a single filament 2 contact bulb. H4 is a dual filament 3 contact bulb.
Old Dec 26, 2005 | 05:28 AM
.....so back to the thread topic....
I'm prolly gonna try this method out....so this is how everyone does it? jus wanna make sure...
Old Jan 4, 2006 | 11:05 PM
bump
