H4 Hi/Lo HID kit
Old Jan 1, 2006 | 08:26 PM
meatbag's Avatar
H4 Hi/Lo HID kit
Will this type of hid bulb fit in the 2005 headlight housing for the fogs/hi?
http://cgi.ebay.com/ebaymotors/McCul...24955077QQrdZ1
Or would a dual bulb setup like this work with our housing?
http://cgi.ebay.com/ebaymotors/6000K...25097660QQrdZ1
They are both H4's but i dont know if they will fit with the reflector peice thats in the housing already.
Old Jan 1, 2006 | 09:57 PM
USANSealKYoon's Avatar
Stealth
be smart and retrofit like me.
that first kit cost 410 +shippingprobably around like 430
projectors are 150-200 ballasts are 200 and a bulbs are 55. and you get a sharper line and won't **** off the person on the other side of the road
Old Jan 2, 2006 | 12:06 AM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
The H4 fog/high isn't the easiest to retrofit. You'll have to mess with the wiring to keep you high beam functional. I think you'll just need a 75 cent diode going from the high to the low circuit, but to be safe, I put in a complete wiring harness with relays and fuses for the fog/highs when I did my retrofit.
Old Jan 2, 2006 | 12:44 AM
meatbag's Avatar
Projectors dont automatically give you hi/lo beam option.
Im looking to have HIDs in the fog/hi's and thats why i was looking at these.
Old Jan 2, 2006 | 01:55 AM
sd_diver's Avatar
The first one...
I've been in email to the seller of the first auction. He's in the OC about an hour away, and will install them for $50. I am going for the 4700K lights
http://cgi.ebay.com/ebaymotors/McCul...25967746QQrdZ1.
The 2nd kit that you are looking at only seems to use an HID for the high beams and a halogen (tinted bulb) for the fogs. Also, the amount of "stuff" to add in looks more cumbersome than the first. Also, there was another post a couple days ago from someone who got this kit at https://g35driver.com/forums/g35-sedan-v35-2003-06/80000-upgrade-foglights-xenon.html. I'll probably get it installed in the next couple of weeks...
sd_diver
Kelvin Style006
May 23, 2016 03:47 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
twentyeggs
Sep 11, 2015 03:58 PM
