Just installed lights (left fog is not that bright)
Old Feb 24, 2006 | 02:19 PM
richboy's Avatar
MORE POWER PLZ!!!
I just installed my lights yesterday and my left fog light is kinda weak. When i turn on the fogs its really bright on the right side and the left its really weak. When i went outside to check it out i could tell that the right side has more reflection of light then the left. Any suggestions on what to do?
Old Feb 24, 2006 | 07:15 PM
Zouk's Avatar
Try looking at the fuse for the left fog light as it may of blown. I know for certain Japanese cars, even if a fuse for a light has blown a small amount of power still gets to the bulbs which produces a very dim light.
Old Feb 25, 2006 | 06:15 AM
richboy's Avatar
MORE POWER PLZ!!!
How do i replace it? If its blown?
Old Feb 25, 2006 | 07:38 AM
Zouk's Avatar
Look in your manual to see if Infiniti provide spare fuses in the fuse box. If they do then replace the blown fuse. If they don't then go to an auto shop and buy one. Make sure you buy/use a fuse with the same amp.
You can see if the fuse is blown because the metal link inside the fuse will be broken.
Old Feb 25, 2006 | 03:11 PM
richboy's Avatar
MORE POWER PLZ!!!
okay thanks. But i dont get how it could blow i had my car for only 2 months
Old Feb 25, 2006 | 11:42 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
I'd take the fog out and put it back in again, it might not have settled in the housing right and is sitting at a weird angle where it isnt reflecting like it should. its worth a try as it only takes 10 mins to get it out.
-GP-
Jusseth
Sep 13, 2020 12:25 PM
wonderizm
Sep 24, 2015 03:09 AM
Freddy07g35
Sep 17, 2015 08:53 PM
attarday
Jul 15, 2015 04:03 PM
