Light Problem
Old Mar 7, 2006 | 10:32 PM
Xman's Avatar
Light Problem
My lower console illumination lights are out, so are my tails but my stop lights work. Any ideas?
TIA,
X
Old Mar 8, 2006 | 06:36 PM
Xman's Avatar
Well time to study some wiring diagrams out of the ESM. Ugghh.....
Old Mar 11, 2006 | 12:46 PM
Xman's Avatar
Culprit found. Blown 10A fuse in the IPDM E/R.
Old Mar 11, 2006 | 04:22 PM
jtesensky's Avatar
Happened to me too, when I tried to hard wire a PAC adapter. Took me forever to find it.
Old Apr 8, 2006 | 12:32 PM
Raheel's Avatar
I have the same problem, what fuse or thing Do I need to FIX
Old Apr 8, 2006 | 12:44 PM
jtesensky's Avatar
It's in the fuse box behind the battery in the engine compartment marked "tail lamp"
Old Apr 8, 2006 | 12:59 PM
Raheel's Avatar
I have a 03, I check all the ones in the ENgine Compartment Fuse Box, they are all working,
MY TAIL LIGHTS
RADIO LIGHTS
SIDEMARKERS
LICENSE PLATE LIGHT
NONE ARE LIGHTING UP
I WILL CHECK AGAIN I GUESS, you sure its the one next to the battery theres only liek 7-8 fuses there, I checked them
Old Apr 8, 2006 | 01:02 PM
Raheel's Avatar
I just checked they are all good, and none of them says Tail Lamp
Old Apr 8, 2006 | 02:20 PM
jtesensky's Avatar
It is buried under the passenger side cowl. It is in a fuse box that is only exposed when you remove the cowl so you can see directly behind the battery. It's a 10 amp fuse marked tail lamp. I just went out to my car and took off the battery cover and the cowl piece and saw it...
Old Apr 8, 2006 | 02:22 PM
Raheel's Avatar
theres only like 4-5 fuses nothing says Tail Lamp
Old Apr 8, 2006 | 02:31 PM
Raheel's Avatar
Old Apr 8, 2006 | 02:38 PM
jtesensky's Avatar
Check it...
Old Apr 8, 2006 | 02:46 PM
Raheel's Avatar
I Love You Man!
Old Apr 8, 2006 | 02:50 PM
jtesensky's Avatar
You'll see the 10 amp fue at the very top of the stack once you take the fuse box cover off (you have to slide the cover up BTW)...
Old Apr 8, 2006 | 03:01 PM
Raheel's Avatar
Got it done thanks man
