OEM FOG LIGHT SAFE?
Old Sep 15, 2003 | 03:24 AM
hellsfire119's Avatar
OEM FOG LIGHT SAFE?
I just changed my fog light with Phillips 5000 12V6o 55W, just curios since it is same voltage as oem fog light, if i leave them on while i driving, will they burn !!??
Old Sep 15, 2003 | 07:48 AM
juiceman's Avatar
Re: OEM FOG LIGHT SAFE?
Voltage on a car is constant 12V DC
The thing that varies the is amoun tof current or ampacity which is directly related to Watts. I think if you do a search on fog lights you will find the correct wattage of these bulbs is 55/60 watts, If I remember correctly
Sticking with the same watts on a bulb is safe usually unless it is a real cheap bulb that will heat up too much.
Have a healthy day!
93 J30t, Black on Black (sold as of 9/10)
03.5 G35, Black on Black
Old Sep 15, 2003 | 03:08 PM
narkotic's Avatar
If you wanted to get real technical, voltage on a car is not 12v constant. It is variable from 11 - 14.4vDC depending on charge conditions, RPM level of alternator, etc.
Old Sep 15, 2003 | 03:33 PM
juiceman's Avatar
You are correct as the voltage in residential is 115vac +/- 20%
Power generation is not always constant due to drains etc. But systems are designed around an median voltage.
I was talking in terms of general so a person would not go out and try and get an 11v bulb. Don't say it would not happen. There are still people thinking a tornado device increases fuel economy.
Have a healthy day!
Old Sep 16, 2003 | 02:22 AM
Jedi's Avatar
Zzzzzzzzzzzzzzzzzzzzzzz! lol
"Use the Forced Induction Luke!"
-Jedi
2003 G35C, 6MT, Navi, Black Obsidian/Graphite
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
attarday
Jul 15, 2015 04:03 PM
