FS: Custom "quad" projectors 03-04 sedan...lucky!
Old Dec 22, 2010 | 09:03 PM
Heist.'s Avatar
Exclamation FS: Custom "quad" projectors 03-04 sedan...lucky!
Selling the car so I'm parting my headlights. These are for the 03-04 sedans and were completely custom. The Bi-xenon feature was removed because I didn't have any need since this was plenty of light and I needed space. I will include all the hardware incase you want to mount the solenoids.
Equipment:
FX Bi-xenon upper projectors ( used as the HIGH beams ) 200$
M3 Bi-xenon lower projectors ( used as the normal headlights ) 200$
LED running lights 10$
DDM 55w ballasts upper and lower with wiring done 150$
"Iron man" red custom lights. ( Run off a separate power source ) 30$
6k bulbs on both upper and lower projectors 50$
Custom upper shrouds and lower shrouds 100$
Black Ebay headlights 250$
Information:
These will need some adjustments.
First off the cutoff point needs to be adjusted, but its pretty close.
You have to use your turn signal bulbs and upper plastic backing I can't find them.
The clear over the lens seems to be peeling, but should be fixed with rubbing compound
Everything else is pretty simple. The projectors come wired and ready to go. Plug and play with the original connectors. The custom red lighting will have to have a separate power source ( 12v running lights would suffice ).
Asking 650$ plus shipping, but if this does not sell within a week or so I'm going to sell it all in pieces.
I will add some better pictures when I can get some light tomorrow.
Old Dec 22, 2010 | 09:07 PM
CandlestickPark's Avatar
ill Sedan
Sick set of quad projectors. GLWS!
Old Dec 22, 2010 | 09:08 PM
Heist.'s Avatar
thanks marcus!
Old Dec 22, 2010 | 09:14 PM
SDGenius's Avatar
are those "apallo" lower shrouds?
Old Dec 22, 2010 | 09:21 PM
SN00P's Avatar
CLUB MODERATOR
bump for a great guy !!!! if they fit on my 06 sedan i would get them !! want to make me some :-)
Old Dec 22, 2010 | 09:38 PM
Heist.'s Avatar
yeah from the retrofit store.
Old Dec 22, 2010 | 10:57 PM
FlyingLumpia's Avatar
Sent u a pm
Old Dec 23, 2010 | 12:13 AM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
That's a really low price that doesn't really cover all the material costs, and the buyer would basically be getting many hours of labor free. GLWS.
Old Dec 23, 2010 | 12:25 AM
TIAN's Avatar
Hold The Line
This! Bump for a sick set at a low price
Old Dec 23, 2010 | 12:28 AM
kennymo's Avatar
is that all you are sellling from your car?
Old Dec 23, 2010 | 12:38 AM
S 854's Avatar
Hot damn this is about the only time I wished I had an 03/04 sedan.
Crazy deal here.
Old Dec 23, 2010 | 12:57 PM
Heist.'s Avatar
thanks everyone! bump someone take these asap.
Old Dec 23, 2010 | 01:00 PM
Heist.'s Avatar
pending sale.
Old Dec 23, 2010 | 02:05 PM
Heist.'s Avatar
Getting pms about the red led lighting wiring. so...
The red leds are on another line with an inline fuse connected to the battery. I have an on/off switch which I will include, but my custom bracket will be sold with my nitrous kit. Here is the picture of the switches, but again only including the wiring and one switch for the LEDS
Old Dec 23, 2010 | 02:07 PM
kennymo's Avatar
what about the muffler and suspension
