The M-Spot For General discussion of the M35/M45
$430 30k service???
Old Nov 3, 2008 | 09:36 PM
Elderado's Avatar
$430 30k service???
I just bought a m35 sport with 27k. I called the dealership to ask about a routine service and they quoted me $430!!! Is there anyway to get a routine maintenance for less?
Old Nov 3, 2008 | 09:46 PM
mIKE's Avatar
Go to Jiffy Lube. However, if they mess up....
And of course, they'll try to upsell you everything and you'll probably end up spending more.
Old Nov 4, 2008 | 01:39 AM
Elderado's Avatar
Thanks!
Funny! I live in Riverside. I'll call the EZ lube I used to take my I35 to, maybe they can do everything the dealership can do but for less i.e. cabin filter, etc...
Old Nov 4, 2008 | 04:45 AM
jayog35's Avatar
diy
Old Nov 4, 2008 | 12:12 PM
mIKE's Avatar
Keep in mind everything they use is aftermarket parts, not genuine OE parts.
Old Nov 4, 2008 | 12:16 PM
TurTLe*'s Avatar
30k.. isn't that just oil change, cabin filter, rotate tires... and inspections? and then the 40k is the ATF, diff, etc... ?
$430 isn't that high of a price if its ATF and etc.
DIY on just parts alone are about $150ish
Old Nov 4, 2008 | 02:13 PM
azng45's Avatar
some people don't know how to DYI... try to look around in this forum if some one from your local can do it cheaper..
Old Nov 4, 2008 | 04:20 PM
mIKE's Avatar
Our 30k service includes:
Oil change
Oil filter
Tire rotation
Tire balancing
replace air filter(s)
replace in-cabin microfilter
Transmission fluid exchange
Oh, and we litterally check out the entire car for anything else that may need to be done.
All parts and fluids are OE unless otherwise specified/requested by the customer.
You WILL get a loaner G35, as this service is rather time consuming.
Old Nov 4, 2008 | 06:43 PM
TurTLe*'s Avatar
i had a m35 as a loaner =P... are all dealership doing the FREE loaner as a courtesy thing or is infinti pretty much making it happen?
can you break down the trans fluid exchange in terms of an X model?
rear diff, front diff, transfer case, front trans,
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
