The M-Spot For General discussion of the M35/M45
What is the MOST aggressive offset for Y50, +'05 M?
Old Mar 25, 2009 | 02:29 PM
bavarian06's Avatar
I'm looking to put rims on my M. I've did some research from all the threads and was wondering if there are any additional information other members can share with me.
I saw someone run 20x9 ET 23 and 20x10 ET 23 and 20x9.5 ET 24 and 20x10.5 ET 29. I think these were the most aggressive for the 20" sizes that I saw. I cant confirm if they did fender work or not (which I'm not looking to do). I know the M's fenders cant be rolled since they are rolled in already, most you can do is pull them out.
Anyone know if the fender width is the same on the G35 Coupe? I'm amazed, for a little car, the G35C can fit 20x10.5 ET 23 on the rear.
Plus, anyone know the max sizes and offset for 19" rims?
Thanks, any help will be appreciated.
Old Mar 27, 2009 | 06:27 AM
Triple8Sol's Avatar
I'd def be interested to know what is considered aggressive for the Y50. FYI though, 10.5 +23 rear is conservative for a G35c.
Old Mar 27, 2009 | 03:54 PM
bavarian06's Avatar
correct, i know 23+ is the max without having to do fender roll/pull.
so far im hearing 20x10 ET 31 is the best for the M. anything more will require a lot of work or you run negative camber.
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
