Vossen Fitment
Old Jul 17, 2015 | 10:25 PM
Soumilg's Avatar
Vossen Fitment
So I have a question about what spacers I woudk need for the set up in looking for. I am installing eibach prokits which drops the car about .9-1.3inches all around and have a set of CV5s..the specs for those are 20x9 +38 wrapped in 245/30 in the front and 20x10.5 +45 wrapped in 275/30 in the rear. I bought the higher offset so I'd have some room to play around with the fitment. Vossen recommends that I go with a +20 in the front and +25 in the rear but I would want the wheels to tuck slightly but be as close to the fender as possible without rubbing and I'm afraid that that set up with cause the fenders to drop on the wheel if I don't have some camber. I have rolled the fenders but don't want to camber it because I drive about 70 miles a day and my tires would be gone so quickly, just gonna get an alignment as close to spec as possible. Since there wasn't a thread out there like think and I've heard of a couple people with this problem if figure it could benefit. Let me know what you guys think I should do. Thanks
Old Jul 18, 2015 | 12:34 AM
Lartytiejdke3's Avatar
There's a reason vossen is the laughingstock for wheels among car groups
Those are still weak specs both with and without spacers
And no comment on their poor quality either.
Old Jul 18, 2015 | 09:24 AM
Soumilg's Avatar
What do you mean by weak specs??
Old Jul 18, 2015 | 12:29 PM
VenomGT9's Avatar
AKA it's not a very flush nor aggressive fitment for a coupe (I'm guessing it's a coupe).
You'd have to run at least 25mm spacers all around to get a good stance and won't be "cambered' out.
There are tonsssssssssssssssssssssssssssssssssssssssssssssss ssssssssssssssssssssssssssssssssssssssssssssssssss ssssssssssssssssssssssssssssssssssssssssssssssssss sssss of threads on wheel fitments and suspension/wheel set ups. Do a quick search and go through the pages to find what you like in the threads.
Word of advice for future posting, if you're asking about wheels, just give the specs without the wheel brand or model. Most drivers on here are going to be hard pressed about Forged wheels only so when you mention a cheaper quality, you will more than likely get some flak in return. It's your choice on where you place your money, but wheels/tires aren't the place to cheap out.
Enjoy the ride!
Old Jul 18, 2015 | 12:33 PM
Soumilg's Avatar
Enjoy the ride!
I figured that but then when it's dropped wouldn't the 25mm spacers cause rubbing
KruZZe
Feb 27, 2023 05:04 PM
Kelvin Style006
May 23, 2016 03:47 AM
magnetism80
Jan 27, 2016 12:57 PM
Extreme Dimensions
Exterior-Vendor
Oct 29, 2015 10:24 AM
the93owner
Oct 4, 2015 09:40 AM
