G35 low idle help!
Old Sep 2, 2015 | 12:39 AM
Jnm07's Avatar
G35 low idle help!
I got a 04 g35 6mt. Every morning when I start my engine I have no problems on a cold engine. When I start it on after warming it up, it would stall out. I'd have to rev it a bit to keep it from stalling. I could drive it after revving it, no problem at stop lights. It drives fine, no stalling. Just really low idling till about the first line. I just need help on why it stalls on a warm engine when starting it up and why does it idle so low. lmk guys! This is driving me nuts.
Old Sep 2, 2015 | 07:11 AM
VenomGT9's Avatar
Check oil and coolant levels when the motor is cold.
Clean the MAF
Check the fuel lines/pump
Old Sep 2, 2015 | 12:47 PM
Mustang5L5's Avatar
No check engine light?
Old Sep 2, 2015 | 05:47 PM
Jnm07's Avatar
Oil is good. Coolant levels are good too. I'm guessing it's the maf or the tb cause before all this, I was cleaning my k&n drop in filter with the recharge kit. Is there any diy on cleaning the maf? I've did my research but nothing. I don't wanna screw things up.
Clean the MAF
Old Sep 2, 2015 | 05:48 PM
Jnm07's Avatar
Nope
Old Sep 2, 2015 | 10:17 PM
ScraggleRock's Avatar
Buy this and spray the plate and connectors. I promise it's your MAF.Name:  IMG_1627.jpg
Old Sep 2, 2015 | 11:42 PM
Jnm07's Avatar
Thanks! But do I take the maf out or could I just leave it in? Also how long do I have to wait till I can start the car back up after spraying?
Old Sep 2, 2015 | 11:51 PM
coffeysm's Avatar
On mine you need a tamper proof torx to take out the actual sensor. You can pick up a whole kit of bits at Harbor Freight for like 10 bucks.
You can try taking out just the plastic housing the MAF sits in and spray it carefully, but I'd rather just get the set of bits.
Spray the sensor, let it air dry, and then put it back in.
Old Sep 3, 2015 | 10:26 AM
Mustang5L5's Avatar
What's the general state of tune of the car? When was the last time you did such things like change the air filter, clean the MAF, or change the spark plugs?
Old Sep 3, 2015 | 09:34 PM
I just sprayed it while it was still in the plastic housing (with it taken off the car obviously). Stuff dries really quick like brake cleaner, but I waited 10 mins before I reinstalled. Fixed all my idle issues including hunting, low idle, stalling, etc. While yer at it, you should clean the TB and replace your PCV valve and you'll cover all your metered air bases. Car will run like a champ.
Old Sep 5, 2015 | 01:16 AM
Jnm07's Avatar
Thanks guys for the replies. I just got a bottle and gonna do it in a bit. Let's see how it goes. Wish me luck.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Rehman2009
Jul 27, 2015 03:23 AM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
