Will 20" 275/30/20 cause problem with VDC
Old Apr 30, 2005 | 03:33 AM
moto35's Avatar
Hi guys, i was wondering if 275/30/20 in the rears will cause any problems with the VDC. can anyone confirm this?
I was told by a tire shop that if i went 275/30/20 the VDC will turn off, not sure if he is right or not.
also, anyone know where i can get some tires for cheap? thanks in advance for the replies. i will post pics of my new 20's when i get the tires. for now, the rims are a SECRET
Old Apr 30, 2005 | 06:29 AM
SilverII's Avatar
if you are less than 3% change in OEM diameter, you should be fine.
Old Apr 30, 2005 | 07:06 AM
brittain's Avatar
you should be fine, that is only .72% off. Im going to either go with that or the 285/30/20. the tire calculator at http://www.1010tires.com/tiresizecalculator.asp will help you out.
Ive been shopping around today, and www.tirerack.com has pretty good prices. a set of BFG KDW2 for $1150- not bad.
Old Apr 30, 2005 | 01:02 PM
G352NV's Avatar
Never enough
I havent had any problems.
Old Apr 30, 2005 | 01:33 PM
RacerX35's Avatar
No problems here, and I have 285/30/20.
Later,
Ray
Old Apr 30, 2005 | 02:18 PM
GTom35's Avatar
Yeah there should be no problem, the will be less spinning anyway due to the weight of the wheel. But why would you put 20''s on. That will slow your car.
Old Apr 30, 2005 | 02:39 PM
moto35's Avatar
20" compliment the car very well. thats why.
anyone have issues with 275/35/20?
Old Apr 30, 2005 | 02:45 PM
moto35's Avatar
if this tire calculation is accurate, 275/30/20 will be just fine. however, 275/35/20 will cause a diameter difference of over 3% which may cause brake failure! thats pretty risky.
Old Apr 30, 2005 | 03:31 PM
littlegbuddy's Avatar
I have 275/30/20's on the rear of mine lowered with the eibach pro kit and have never had any issue with the VDC.
Old Apr 30, 2005 | 04:22 PM
DanielEshaghian's Avatar
How much is the drop with the eibach pro kit and can u post a pic?? Did you get shocks with the springs or did u just do springs? Thanks
Old Apr 30, 2005 | 11:08 PM
borahatch's Avatar
Same here.... 275/30/20 and not one issue with VDC. It still kicks in when things get out of hand just as if I had my stock size.
Thebaws11
Jul 2, 2021 11:36 AM
wuzz-upp
Oct 3, 2015 04:21 PM
mattdg35
Sep 14, 2015 11:28 AM
