20" rims, tires and VDC
Old Jan 23, 2006 | 07:29 AM
Polishthrust's Avatar
I have a 05 coupe, and I was looking into getting some 20" rims, 8.5 front 9.5 back. The offsets are 20mm front and 35 back. (No brembo)
After some research i decided to go with Falken Azenis ST115 tires because they are quiet and have good wear rating. The problem is that they dont make a 275/30/20 tire, but they do make a 275/35/20.
My question is this:
Would it be ok to have a 245/35/20 & 275/35/20 set up? Or would the VDC just go nuts on me?
I like the idea of having a little more "meat" on the back tire. With 275/30/20 the back tire is actually a TINY bit smaller then the front.
Does anyone know if there would be rubbing? The car is not lowered.
Old Jan 23, 2006 | 08:09 AM
m500's Avatar
Assuming there is no change in the ECU from 03 to 05. You can alwasys take it back to have the dealer set your new tire diameter to have you VDC work correctly.
Old Jan 29, 2006 | 01:17 AM
Silverbolt's Avatar
I have that tire size and my VDC is fine. It only goes off when its supposed to.
Old Jan 29, 2006 | 02:11 AM
Sponger's Avatar
6MT Brembo Coupe
VDC will be happier with 275/35/20
Old Mar 13, 2006 | 01:17 PM
CMOLINAG35's Avatar
Your Good With Those. I Have 20"s With The Falken St-115's And 275/35/20 Rear. There Perfect !
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Jussumman
Dec 22, 2015 10:23 AM
BlackGee35
Jul 31, 2015 11:04 AM
