Wheel Spacer Reference Guide
Old Sep 11, 2014 | 08:42 AM
Hogbone's Avatar
Hi,
Please share your photos of your lovely ladies (car) so that we people like me can have a general idea of what are coupes look like with different variations of wheel spacers.
Plz include wheel spacer size, wheel specs if running aftermarket wheels (i.e rim width, +/- of offset), and plz include the amount of suspension drop you are running. If your set-up include camber, caster, or toe adjustment plz list it.
Old Sep 11, 2014 | 09:21 AM
Hogbone's Avatar
I'd go first but I have yet to buy my wheel spacers. But I plan to run a 25/30mm or 20/25mm (I.e front/rear) an I plan to use my oem 18s.
Old Sep 11, 2014 | 09:43 AM
ScraggleRock's Avatar
Do 25 all around with the OEM 18s. I have the 20/25 setup and I want just a touch more in front.
Old Sep 11, 2014 | 10:17 AM
Hogbone's Avatar
Noted. Thanks! Plz share a photo of your wheels fittment inside your fender well
Old Sep 11, 2014 | 10:28 AM
I will when I get home around 2pm PDT.
Old Sep 11, 2014 | 01:46 PM
Lartytiejdke3's Avatar
Prob the most popular spacer size with OEM rays
20/25 H&R Spacers
Old Sep 11, 2014 | 03:32 PM
Shawno72's Avatar
I also have H&R 20/25
Old Sep 11, 2014 | 03:46 PM
Hogbone's Avatar
Nice ! Thanks shawnno and jersey! Anyone else?
Facebook member told me to go with these. http://www.ebay.com/itm/380972451308 but I just don't know about the Quality of these
Old Sep 11, 2014 | 03:48 PM
Shawno72's Avatar
You can't argue the quality of H&R
Old Sep 11, 2014 | 04:18 PM
Rear: 25mm
Front: 20mm
Like I said, I'd like 25 all around, but what tires are you running? Mine are the staggered setup. Also keep in mind how low you are and how much camber yer running. I'm running -0.9 on the front and -1.4 rear.
Old Sep 11, 2014 | 05:13 PM
Hogbone's Avatar
Nice! I'd like a little bit more tire on the front too, so I'll run the 25/25mm set-up
I'll edit the OP and add tire size and the amount of camber. I'll post my spec after work
Old Sep 11, 2014 | 05:18 PM
Hogbone's Avatar
The hubcentric lip is a must have, no?
Old Sep 11, 2014 | 05:47 PM
thegreatkwijibo's Avatar
Rear: 25mm
Front: 20mm
Old Sep 11, 2014 | 06:07 PM
Hogbone's Avatar
Ight I'm running Goodyear 225/45 front and 245/45 rear. Ride height is 26in, now that's from the ground up the the center of the fender. Camber is nature as I haven't add camber kit yet
Old Sep 11, 2014 | 08:05 PM
Originally Posted by thegreatkwijibo
I've been thinking about it, man. I just don't like that tucked look. I like that "how the hell did you get the tire that close to the fender without being tucked" look. Think I need a 350z pro kit..
