I've been modding the sedan lately
Old Jan 9, 2008 | 09:18 AM
Gilley's Avatar
Since there isn't a whole lot more I can do to my coupe without spending a lot of money, and since my sedan needed new shocks and had a camber issue even on stock springs, and since I had the Brembos from my coupe handy (after installing the Rotora BBK on it), and since I won a set of Cobb Tuning sway bars at a raffle, I decided to put them all together on the sedan.
I also added stainless Stoptech brake lines, R1Concepts drilled and slotted rotors in the Brembo configuration, stock 350Z rear springs, and Tein 350Z S-Techs up front with Tokico D-Specs all around, and SPC camber arms front and rear, with the toe bolts. I took the D-Specs and the S-Techs off of my coupe after I bought a set of BC Racing coilovers.
The tires were wearing on the insides even on stock suspension, so I decided to get the camber kits, and figured I might as well lower it as well. I first installed the S-Techs all around but the rear springs made the rear wheels tuck inside the fender wells. I also rolled the rear fenders. The OEM Z springs leveled the rear even with the front.
After getting it aligned today, the ride is so much better, but not harsh at all. And the ride hight is much improved, as is the stopping ability. I think I'm about done with mods on this car though.
Here are a few pics.
The rear was tucked with the S-Techs in the rear.
With OEM Z springs in the rear.
Both G's.
Old Jan 9, 2008 | 09:34 AM
da mayor's Avatar
looking good... i wanted to find a CB sedan
Old Jan 9, 2008 | 09:55 AM
Texasscout's Avatar
So you had a four wheel alignment? I don't have the kits yet, but would a toe end check help my high speed stability any?
Old Jan 9, 2008 | 10:02 AM
ttrank's Avatar
Grocery getter
Ah it has started!
Mr. Gilley round 2
That's a great start.
Old Jan 9, 2008 | 10:08 AM
tragedycat's Avatar
Sedan looks awesome with the brembos, you really should get the bottom portion painted though.
Old Jan 9, 2008 | 10:18 AM
bert039's Avatar
Great start, but the sedan looks like crap next to the coupe. You can't stop now! Get the aero kit and some rims
Old Jan 9, 2008 | 10:25 AM
Swivel's Avatar
Moderator
Z springs really improved the stance of that car. Looks great, good work, Gilley, wanna do mine?
Old Jan 9, 2008 | 11:14 AM
Gilley's Avatar
Yes, 4 wheel alignment.
I don't know if the tow check would help with the high speed atability. I'd suggest getting the kits and getting the alignment done then.
Originally Posted by ttrank
Ah it has started!
Mr. Gilley round 2
I am pretty sure I'm about done on this one. I can't afford to go full blown on the sedan. My wife has to drive it sometimes.
I'd love to if it were inexpensive.
Drive on down to Orlando and we can take care of it.
Old Jan 9, 2008 | 12:43 PM
Klubbheads's Avatar
sell me those brembos!, ur wifey doesn't need those brakes.
Old Jan 9, 2008 | 03:19 PM
Gilley's Avatar
I drive the car a lot too, so no. And I'll need them if I ever return the coupe to stock or sell the Rotoras.
Old Jan 10, 2008 | 05:13 AM
dec55's Avatar
:lol Actually I think the Sedan looks gorgeous... It defintely has more presence,
when with the coupe in the picture. Both cars complement each other.
Old Jan 10, 2008 | 11:26 AM
bert039's Avatar
Don't get me wrong, the sedan looks good. Its just that the coupe looks so much more completed.
Old Jan 10, 2008 | 03:10 PM
darnelled's Avatar
Paint the lowers to match and you're done.
Old Jan 10, 2008 | 03:20 PM
ttrank's Avatar
Grocery getter
Ah just see if they'll make you an even larger kit for the sedan! Maybe some 16-pot with 16" rotors!
Old Jan 10, 2008 | 06:25 PM
03Sg35's Avatar
hey can you look at your rear brembo calipers and let me know if the bleeders point down or up. Ill be doing the oem brembo swap just wanted to know if there is a diffrence thanx
