OEM Coupe 19"s painted Graphite
Old Oct 3, 2008 | 04:46 PM
Fabrikator's Avatar
Originally Posted by MixturePinoy
I hope you let them cure for a while. that paint is pretty soft when it's has many layers. A month after I did mine you can see dirt, dust, and brake particles embedded into the paint. I'll probably do mine over again, but this time let the paint cure for a longer time than a day.
so far theyve been curing for 3 days.. but I gotta go out today, so I have no choice.. hopefully it will be alright
Old Oct 3, 2008 | 04:47 PM
G35Papa's Avatar
Nice work.
Old Oct 6, 2008 | 04:25 AM
Fabrikator's Avatar
Some new pics.. inc my facked up manuel norega style front bumper and, pics with the front brembos on.. (still waiting on the rear rotors to come in )
Old Oct 6, 2008 | 12:27 PM
naughty240's Avatar
Look real good. Nice job
Old Oct 7, 2008 | 11:42 AM
SLVR JDM's Avatar
I think you've inspired me to try this on my winter wheels. Couple of questions for you.
-On your initial sand with 250 grit, did you take it down to the primer, or just rough it up enough that the paint / primer would stick? How did you clean them before you started?
-What was the reason for sanding after the clear coat?
-Did you paint the wheels with the tires mounted and just tape them off?
-Did you paint the inside of the wheels at all, or tape those off in some way? Wondering if you got any overspray or how you handled that.
Thanks~!
Old Oct 7, 2008 | 02:01 PM
Fabrikator's Avatar
Thanks~!
I just used wheel cleaner to wash the wheels off.. Used a brush for the really grimey parts with baked on brake dust. you could use dishwashing detergent too, it removes oil well.
For initial sanding, basically you want to remove the clear coat, it you sand a bit too much and take off a bit of the paint, its ok.. should look something like this.
Yea i just taped off the tires as seen in pic.
Yes i painted the inside of the wheel, but only with primer, and the base Black coat. you probably also want to paint around the hub area as you will be able to see that with the wheel mounted.
Take your time and dont coat it on too thick on a single pass. If you happen to get overspray or drips, wait 10 mins until the rest of the rim is fairly dry, and take a Q-tip, and carefully press down on the drip.
the wet sand on the clear coat is for imperfections or overspray.
Good luck, and take your time. good prepwork is what is going to make the diffrence.
Old Oct 9, 2008 | 11:39 PM
OCsGDurty5's Avatar
looks hella clean!black out the chrome trimming door handles and grill and this thing will look mean.very aggressive looking
Old Mar 5, 2009 | 07:48 AM
stephenw's Avatar
Your wheels look awesome. Great job!
How many cans of paint (for each type) did it take to do this?
Primer, Black, Graphite, Clear?
You said you let your wheels cure for 3 days. Did you find that to be long enough?
I'm going to do this soon. Any advice to share from your experience?
Old Mar 5, 2009 | 03:41 PM
driguez's Avatar
Agree with TTRANK, black out your handles and grill, and if you can your headlights as well. Nice job on the rims BTW.
(Sorry for the crappy quality pic, took it w my phone, will post better pics after this weekend.)
Old Mar 5, 2009 | 03:54 PM
Jeff92se's Avatar
Red Card Crew
Man, I so want to paint my coupe 19s but I'm not too sure how a really dark wheel would look on a BS sedan. My 19s are curbed checked but not too bad.
Old Mar 5, 2009 | 04:51 PM
FutureGDriver's Avatar
Originally Posted by Fabrikator
Finally finished painting the Coupe 19s.. im very happy with the way it turned out. Sorry for the crap pics, the only Digi cam I have is my phone. Ill take some better ones once the Brembos are on.
I used all Duplicolor products
sand 250
2 coats, primer, wetsand 600
2 coats black wheel paint
3 coats graphite wheel paint
3 coats clear, wet sand 1500
Dude u coulda bought wheels with that amount spent but oh well to each it's own
Old Mar 5, 2009 | 09:18 PM
Fabrikator's Avatar
I traded my factory 17's for these Forged 19's and gave the guy $300 cash. (with tires)
the paint and everything cost me $90.
So it didnt cost me much. duno what kinda wheels u can get for $400 ?.. prob wouldnt put them on my car lol
Old Mar 5, 2009 | 09:24 PM
NaiveRapture's Avatar
I'm going to do my stock 18's in gloss black this weekend... thanks for the pictures Hopefully mine turns out pretty good, we shall see.
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
djreinx
Jul 13, 2015 05:04 PM
