OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Mar 16, 2011 | 03:14 PM
  #3151
SkyWay's Avatar
245/40/18
Dropped on greddy type s coilovers. I plan to go as low as I need to.
Fenders pinched in front and rolled flat in rear. I can pull rears if I need to as well
Old Mar 16, 2011 | 03:42 PM
  #3152
4DGS's Avatar
I'm not too familiar with the greddy coils (check out the stickys in the suspension section and add your coils to the quick review thread)
If you run like -3 and pull the fenders a tiny bit, you'll be fine.
What wheels are these? I'm intrigued by the fact they're 18s...
Old Mar 16, 2011 | 05:30 PM
  #3153
SkyWay's Avatar
I want to get 18's for the weight. They are enkei rpf1's
Old Mar 16, 2011 | 05:58 PM
  #3154
4DGS's Avatar
So you're worried about weight for performance reasons but you're wanting to stretch and run camber?
Old Mar 16, 2011 | 06:02 PM
  #3155
Heist.'s Avatar
I could of sworn enkei were cast? forged is usually significantly lighter. that MAT tech is so silly ( Most Advanced Technology....come on enkei) could of got a little more specific with it.
Old Mar 16, 2011 | 06:09 PM
  #3156
4DGS's Avatar
^ Flow formed not forged.
My weds were the same 19x10 20lbs.
Old Mar 16, 2011 | 06:10 PM
  #3157
Heist.'s Avatar
yeah I just recall reading the description and being like wtf. haha
Old Mar 16, 2011 | 06:13 PM
  #3158
4DGS's Avatar
Flow formed wheels is what up, forged is a thing of the past IMO. Flow formed is stronger, cheaper and easier. In most instances it's actually lighter than forged wheels.
Old Mar 16, 2011 | 06:17 PM
  #3159
SkyWay's Avatar
It doesn't hurt to have the lightest wheels possible, so why not? I don't want to stretch too much and would like to run as little camber as possible, which is why I wanted the 9.5's.
They are cast and I would prefer forged, but they don't make them. The 18x9.5's weigh 18.6 lbs, and I think the 10.5's are like 19. Pretty light if you compare them to other forged wheels.
Old Mar 16, 2011 | 06:19 PM
  #3160
SkyWay's Avatar
I didn't realize they were stronger. The rpf1's are a replica of the f1 wheels they make.
Old Mar 16, 2011 | 06:20 PM
  #3161
4DGS's Avatar
Then you should probably hold out for the 9.5 or go with higher offset. You're going to have to be low to pull this off...
Old Mar 16, 2011 | 06:23 PM
  #3162
Heist.'s Avatar
I agree its cheaper and easier, but thats it. Forged is still top of the food chain and I don't see it changing.
Old Mar 16, 2011 | 06:25 PM
  #3163
SN00P's Avatar
CLUB MODERATOR
your going to have a good amount of camber with a 10.5 all around and being 18's you will need to be dumped to make it even look good.. fender work front and rear,camber arms and extra money in bank for tires
Old Mar 16, 2011 | 06:35 PM
  #3164
SkyWay's Avatar
To be honest, I don't know how low I can go with my K2 front. They do make 19's, but the cost is significantly higher.
Old Mar 18, 2011 | 02:04 PM
  #3165
CandlestickPark's Avatar
ill Sedan
Best stance/fitment that we've seen on a static 2nd Gen Sedan that I can recall.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
