OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Aug 12, 2011 | 12:32 AM
  #4351
bert512's Avatar
20x8.5 et32 with 245/35/20 & 20x10.5 et30 with 275/30/20 will this work on my 07 sedan and what kinda mods will i need to do? anyone???
Old Aug 12, 2011 | 07:33 PM
  #4352
CandlestickPark's Avatar
ill Sedan
The Stimulation/Donpisto
Wheel spec
20x9.5 -12
20.10.5 +0
Tires225/35
Camber: Front camber is -4.7 and rear camber is -7.5
Fender Work:rear were rolled flat, pulled and flared upward (upward flare not needed/not beneficial).
20x10.5 +0
20x11 -12
Tires235/30 (front) and 235/35 rear
Camber: Front camber is -5.5 and rear camber is -8
Fender Work:rear were rolled flat, pulled, hammered and flared upward. front was pinched with fender finisher.
Other: This setup requires modified front upper A arms, and modified rear camber and toe arms.
Gtfever:
Wheel Specs:
19x9+4
19x10-1
Tires:
215/35
225/35
Camber: -3 camber upfront and -4 out back
Fender work: Pulled
4drmadness
Wheel Specs:
Volk Winnings
19x9.5 +17
19x10.5 +19
Tires:
225/35/19
235/35/19
Camber: -3.8 back and -2.4 front
Fender work rolled flat
STCLAIRWEST
Wheel Spec:
19x9.5 +17
19x10.5 +9
Tires:
225/35/19
245/40/19
Camber: -2.5(fr) -2(r)
Fender Work: Pulled
dz n.u.t.z
Wheels Spec:
TE Rep
19x9.5 + 7
19x10.5 +22
Tires:
235/35/19
265/30/19
LM reps
19x10.5 +12
19x10.5 +22
Tires
235/35
255/35
Camber -3.4 all around.
Wheel Spec:
Challenges
19x9.5 + 16
19x10.5 +23
Tires:
Nexens 245/35/19
Dunlop 275/30/19
Camber: -3.3
Fender work: Pulled
4DGS
Wheel Specs: WEDS
19x9 +10
19x10 +17
Tires:
Falken Fk452 215/35/19
Falken FK452 225/35/19
Camber: 2.3 all around
Fender Work: Mild roll
Wheel specs: CCWs
18x10 +12
18x11 +20
Tires:
225/40
255/35
Camber: Rear -4.7 Front -3.7
Fenders:
rear pulled to fit
Fronts untouched.
sag35777
Wheel Specs
19 x 9 +15
19 x 10 +15
Tires:
nexen 3000 235/35
nexen 3000 245/35
Camber: ???
Fender work:???
Johnnyone
Wheel Specs:
19x9 +9
19x10 +20
Tires:
Toyo Proxes T1R 225/35/19
Toyo Proxes T1R 245/35/19
Camber: -3.5 all around
Fender Work: Pulled
FlyingLumpia
Wheel Specs:
19x9 +32 with a 15mm spacer
19x10 +32 with a 10mm spacer
Tires:
225/40
255/35
Camber:???
CandlestickPark
SSR Professor SP1s
Wheel Specs:
19 x 9.5 +5
19 x 10.5 +18
Tires:
Yokohama S-drive 225/35/19
Yokohama S-drive 245/35/19
Camber: -3 F, ~5.5R
Fender Work: Rears pulled 5mm, fronts pinched flat and flared
Nismo LMGT4s
Wheel Specs:
19 x 8.5 +0 (25mm spacer)
19 x 9.5 +10 (20mm spacer)
Tires:
Yokohama S-drive 235/35/19
Camber: -3 F, -4R
NAT&FFec
Wheel Specs
19x8.5+22
19x9.5+22
Tires:
255/35/19
255/35/19
Camber:-2F/-3R
Fender work: Rears rolled flat fronts pulled
TycoRC
Wheel Spec:
19x8.5 +20 JLBMotorsport Apollo's
19x9.5 +20
Tires:
Nexen N3000235/35/19
Nexen N3000245/35/19
Camber: -3.3 Front -3.75 Rear
Fender Work: Rolled very flat
Fabrikator
Wheel Spec:
20x9.5 +14 (R-disk) Work Gnosis GS-3
20x10.5 +20 (O-disk)
Tires:
Falken FK452 - 235/30/20
Falken FK452 - 255/30/20
Camber -3.3 Front, -6.0 Rear
Fender Work: Front - Rolled very flat and slight pull, Rear - Pulled
Speeddream
Front: 18X9+2 with a 20mm spacer
Rear: 18x10+9 with a 15mm spacer
Tires:
215-40-18
245-40-18
Camber: N/A yet
Fender: front rolled flat and pulled about 3mm, rear rolled real flat pulled about 3mm
JDM_Cain
Front: 19x9.5+2 with 20mm spacers
Rear: 19x11+24 with 5mm spacers
Tires:
Falken fk452
235/35f
255/35r
Camber: aprox -2.5
Fender: Front rolled flat (side marker bracket modified), rear rolled flat and pulled 5mm
CORNELL
19x10 +10(20mm spacer) VOLK RE30
19X11 +25
235/35 Achilles atr
245/35 Achilles atr
camber: -3 front, -4 rear
fenders rolled flat slight pull
Gdup35sedan
PIAA Supper rozzas
19x9 +5
19x10 +10
Tires: 225/35 235/35
Camber: -3.5/-4.0
Fenders: rolled and pulled 5mm F&R
XXR 521
18x10 +15 front and back
225/40
225/45
-3 degrees of camber.
SN00P
Wheel Specs: concept one rs-8
19x9.5+17
19x10.5+30
Tires:
General utp 225/35
General utp 245/35
Camber: front: -3º rear: -5.5º
Fender Work: front: all tabs removed and pinched flat and pulled 3mm rear: cut to the max.
Old Aug 12, 2011 | 07:51 PM
  #4353
b-dRizZy's Avatar
Wheel spec
20x9.5 -12
20.10.5 +0
Tires225/35
20x10.5 +0
20x11 -12
Gtfever:
Wheel Specs:
19x9+4
19x10-1
Tires:
215/35
225/35
Fender work: Pulled
4drmadness
Wheel Specs:
Volk Winnings
19x9.5 +17
19x10.5 +19
Tires:
225/35/19
235/35/19
STCLAIRWEST
Wheel Spec:
19x9.5 +17
19x10.5 +9
Tires:
225/35/19
245/40/19
Fender Work: Pulled
dz n.u.t.z
Wheels Spec:
TE Rep
19x9.5 + 7
19x10.5 +22
Tires:
235/35/19
265/30/19
LM reps
19x10.5 +12
19x10.5 +22
Tires
235/35
255/35
Wheel Spec:
Challenges
19x9.5 + 16
19x10.5 +23
Tires:
Nexens 245/35/19
Dunlop 275/30/19
Camber: -3.3
Fender work: Pulled
4DGS
Wheel Specs: WEDS
19x9 +10
19x10 +17
Tires:
Wheel specs: CCWs
18x10 +12
18x11 +20
Tires:
225/40
255/35
Fenders:
rear pulled to fit
Fronts untouched.
sag35777
Wheel Specs
19 x 9 +15
19 x 10 +15
Tires:
nexen 3000 235/35
nexen 3000 245/35
Camber: ???
Fender work:???
Johnnyone
Wheel Specs:
19x9 +9
19x10 +20
Tires:
Fender Work: Pulled
FlyingLumpia
Wheel Specs:
Tires:
225/40
255/35
Camber:???
CandlestickPark
SSR Professor SP1s
Wheel Specs:
19 x 9.5 +5
19 x 10.5 +18
Tires:
Camber: -3 F, ~5.5R
Nismo LMGT4s
Wheel Specs:
Tires:
Camber: -3 F, -4R
NAT&FFec
Wheel Specs
19x8.5+22
19x9.5+22
Tires:
255/35/19
255/35/19
Camber:-2F/-3R
TycoRC
Wheel Spec:
19x9.5 +20
Tires:
Fabrikator
Wheel Spec:
Tires:
Speeddream
Tires:
215-40-18
245-40-18
Camber: N/A yet
JDM_Cain
Tires:
Falken fk452
235/35f
255/35r
Camber: aprox -2.5
CORNELL
19X11 +25
235/35 Achilles atr
245/35 Achilles atr
Gdup35sedan
PIAA Supper rozzas
19x9 +5
19x10 +10
Camber: -3.5/-4.0
XXR 521
225/40
225/45
b-dRizZy
Wheel Spec: Vertini Wheels
20x8.5 +25 With 15mm Spacer
20x10 +25
Tires:
Achilles ATR 225/30
Achilles ATR 245/30
Camber -3.5 F / -4 R
Fenders Rolled Flat & Slight Pull
Old Aug 12, 2011 | 08:01 PM
  #4354
Berto you noob you have 20mm spacers not 15s.
Old Aug 13, 2011 | 11:25 AM
  #4355
b-dRizZy's Avatar
Lmfao oops I forgot. Haha ^
Old Aug 15, 2011 | 11:58 AM
  #4356
black_gst's Avatar
hey guy im looking at some new wheels for om 05 sedan and im looking for some insight.
specs are:
20x8.5 +13 or +38
I was thinking +13 isnt too agressive, I will be running a 225/35 tire up front, and was hoping to get away without rolling the front fenders
20x10 +13 or +35
for the rear +13 is too agressive for me, i was hoping for a +20 or +25 so im thinking to just go with the +35 and get some 10 or 15mm spacers
Thanks in advance for the help
Old Aug 15, 2011 | 12:05 PM
  #4357
black_gst's Avatar
do you have pictures of the fitment on your front wheels? a +10 will give me a good idea of how +13 would look
Old Aug 15, 2011 | 01:21 PM
  #4358
b-dRizZy's Avatar
ill try to take some today..
buy my wheels. lol
Old Aug 15, 2011 | 02:25 PM
  #4359
black_gst's Avatar
how much are you asking, post pics and ill check them out
Old Aug 15, 2011 | 02:57 PM
  #4360
b-dRizZy's Avatar
pm you ^
Old Aug 16, 2011 | 12:39 PM
  #4361
4DGS's Avatar
Old Aug 17, 2011 | 11:35 AM
  #4362
cornell's Avatar
^NICE! I saw your feature and as always get pushed to do more to my car everytime i see your car. I currently sit at 23 3/4 all around and its ridiculous!!
Old Aug 17, 2011 | 11:59 AM
  #4363
4DGS's Avatar
Post pics foo
Old Aug 17, 2011 | 12:04 PM
  #4364
black_gst's Avatar
Originally Posted by 4DGS
Nice!
do you have you sizes and offsets posted somewhere already?
Edit:
are these still current?
4DGS
Wheel Specs: WEDS
19x9 +10
19x10 +17
Tires:
Old Aug 17, 2011 | 12:05 PM
  #4365
4DGS's Avatar
http://www.stancenation.com/2011/08/...ti/#more-18670
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
