OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Mar 15, 2012 | 03:07 PM
  #5281
Matzo Ball's Avatar
gangsta!
Old Mar 16, 2012 | 03:24 PM
  #5282
jimmyboi860's Avatar
Sooo fellow stretch members...Where can a G find some gangster 215/35/20 tires?
Old Mar 19, 2012 | 08:42 PM
  #5283
4DGS's Avatar
Falken and Toyo are the only two that make em, Nitto MIGHT have a Neo gen in that size as well.
Last of the photos with the CCWs
Feature: http://www.stretchandpoke.com/?p=2836
Old Mar 19, 2012 | 08:54 PM
  #5284
CandlestickPark's Avatar
ill Sedan
^And that's how it's done...
Old Mar 19, 2012 | 09:38 PM
  #5285
iamtimshady's Avatar
agreed.
Blain, what do you run your dampening @ on your GR+ coils?
Old Mar 19, 2012 | 10:02 PM
  #5286
shawndon's Avatar
The light catches the Emerald Mist color just right. Awesome shot!
Old Mar 20, 2012 | 02:48 AM
  #5287
JosansG35's Avatar
post your new setup already 4DGS!
Old Mar 20, 2012 | 05:44 PM
  #5288
4DGS's Avatar
Originally Posted by iamtimshady
agreed.
about 4 from stiff
If I could get my damn rear tires to seat!
Old Mar 20, 2012 | 06:13 PM
  #5289
^can't wait to see this
Old Mar 20, 2012 | 09:40 PM
  #5290
ill Sedan
Just read through the feature, thanks for the shout out Blain! You've easily got one of the top stanced Gs, Sedan or Coupe.
Old Mar 20, 2012 | 11:59 PM
  #5291
4DGS's Avatar
Thanks man, can't help but return that to you though haha.
I'm worried I've gone over the top with my new set up, so we'll have to see lol
Old Mar 26, 2012 | 10:20 PM
  #5292
P10 WRC's Avatar
Okay guys, i am due for some rear tires already. I currently have 255/35/19 on a 10 inch wheel. My rear camber is at -3.5 and i am as flush as i can get with a +27 offset.
Should i stick with the 255's or go with 245's and go about 5mm's more aggressive on the offset? Out front i am running a 19x9+11
I currently have Hankook v12's. Would it look ghetto if i went with the nankangs out back and still run the hankooks up front or should i match them?
Old Mar 26, 2012 | 10:29 PM
  #5293
ill Sedan
What's your front tire size and camber at now. Front is 3mm more aggressive than rear, but I would only suggest going 5mm more aggressive out back if the stretch matched F/R and camber was within a couple of degrees.
Old Mar 26, 2012 | 10:40 PM
  #5294
P10 WRC's Avatar
front camber is at -3. the stretch will not be the same as i am running 225/40's up front. once those tires go, i am going to go for some 225/35's up front to be able to drop the car more. there is just such a price difference between the 255's and 245's
what is you opinion on dif brand tires on the same car?
Old Mar 26, 2012 | 10:57 PM
  #5295
ill Sedan
I would stay with the same tire sizes then. You'll just need a spacer up front if you change up tire sizes up front eventually. You'll also need to go lower because the tires will be shorter. If you want to do all of that given your goals with your fitment then go ahead.
Personally I wouldn't run different brand tires F/R, but I'm pretty meticulous about my car. Some people don't care. If you do different brand tires make sure they stretch similarly.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
