OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old May 1, 2010 | 05:41 PM
  #616
gtrefever's Avatar
does anyone know someone who had/has jic coilovers and know if they can dump the rear of the car?
Old May 1, 2010 | 05:58 PM
  #617
kennymo's Avatar
buy me some and ill let you know
Old May 1, 2010 | 06:00 PM
  #618
4drmadness's Avatar
hahaha dranom has the jic, and im pretty sure u can dump
Old May 1, 2010 | 06:03 PM
  #619
fsasO6's Avatar
they cut the inside of the fenders so that there will be less of a chance of getting waves when pulling them? or just for more clearance?
newb when it comes to pulling.
Old May 1, 2010 | 06:04 PM
  #620
gtrefever's Avatar
itll lessen the change of waves.
btw i think i just bought a nismo front bumper hahaha im hoping on the band wagon
Old May 1, 2010 | 06:05 PM
  #621
4drmadness's Avatar
nice!! the hikatadori one?
Old May 1, 2010 | 06:06 PM
  #622
STCLAIRWEST's Avatar
Nismo FTW
Old May 2, 2010 | 04:32 AM
  #623
kennymo's Avatar
ok guys heres the situation.
here are my offsets...
20 8.5 F and 20 10.0 R
offset: 35 F and 45 R
pretty weak i know. i want to get them flush. but not super flush or anything. i plan to cut the fenders. but do not want to do a pull. i also dont want a crazy amount of camber. my question is what size spacers should i get. and what size tires should i use. and if you have a picture of a setup that you think descibes what i am talking about. please post it. or tell me whos car it is and i will find it in this thread.
Old May 2, 2010 | 04:51 AM
  #624
kennymo's Avatar
after just going through all 42 pages of this thread. and looking at the different offsets people are running on there 20s. i think i have decided that i only want to go with a 30 offset for the rear. so would that mean that i need 15mm spacers since i have a 45 offset right now? as for fronts. i have no idea what offset i would need to match the rear.
Old May 2, 2010 | 06:55 AM
  #625
CandlestickPark's Avatar
ill Sedan
^Correct, you need 15mm spacers to bring your rear offset to +30. The front offset that would "match" the rear is +11, so you'd need a 25mm (+10) spacer if you are looking to match the rear offset.
Old May 2, 2010 | 02:24 PM
  #626
kennymo's Avatar
so 25 front and 15 rear. ok. and what size tires do you recommend? i dont want some rediculous stretch. do you think a 255 would work in the rear and 225 in the front
Old May 2, 2010 | 02:26 PM
  #627
Fabrikator's Avatar
Originally Posted by gtrefever
upfront u can run a 235/35 with atelast -2.5 to -3 camber outback id run a 245/35 and same with the camber -3 at the most
after some research, 235/35 is an odd size.. not too many companies make that size in a 20"..
So I think im gonna run 225/35/20 in front, and either 245/35/20, or 255/35/20 in the rear.
Yokohama S.Drives
Anyone have positive or negative comments on the S.Drives?, performance in the wet, and noise is my main concern, considering the driving conditions here in BC.
Edit for reference: this is on a 9.5" front and 10.5" rear
Old May 2, 2010 | 05:37 PM
  #628
kennymo's Avatar
yea 225/35 is something i can get ahold of a lot easier.
Old May 2, 2010 | 05:53 PM
  #629
Yokohama S.Drives
What are the offsets? If they are low you wont be able to fit a 255/35 without doing fender work
Old May 3, 2010 | 03:48 AM
  #630
Fabrikator's Avatar
+14 front, and +20 rear.. im not opposed to a slight fender pull tho
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
