OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Nov 7, 2012 | 01:10 PM
  #6391
K.C's Avatar
K.C
thanks for the reply mj_39 . will i have room to drop on coils ?
Old Nov 7, 2012 | 11:28 PM
  #6392
asadali91's Avatar
Originally Posted by VMRWheels
+1
Wheel offsets should be on the back of the wheel somewhere. If you're unsure you could always post photos of the back of the wheel, or measure the backspacing and convert it to wheel offset.
SOOO its 20 x 8.5 35+ offset with a 4 inch lip back to my original questions any suggestions?
Old Nov 7, 2012 | 11:39 PM
  #6393
CandlestickPark's Avatar
ill Sedan
I highly doubt that an 8.5 +35 has a 4 inch lip. My front 9.5 +5 has a 4.1 inch lip.
Old Nov 7, 2012 | 11:42 PM
  #6394
ill Sedan
You won't have any problems fitting a 8.5+35 out back. Roll your fenders and run a 245 tire.
Old Nov 8, 2012 | 01:29 AM
  #6395
asadali91's Avatar
there 20's maybe thats why? The tires it cam with are 255 though :S so i think im going to have to roll anyway, plus i want to lower my ride, so when i get my coilovers ill need a camber kit for some room aswell right? If i run intense negative camber then ill have space and the look i want- correct me if im wrong please lol
Old Nov 8, 2012 | 01:37 AM
  #6396
gtrefever's Avatar
You don't need to run "intense camber"
If and when you get coil overs and "slam" your car it will naturally camber in. Even at that you'll want a camer kit to add positive camber. 8.5 +35 isn't aggressive at all. Camber isn't much of a I want thing it's a need. Don't run "intense camber " if it isn't needed which in this case isn't.
Old Nov 8, 2012 | 01:43 AM
  #6397
TGMcCoy's Avatar
My wife's sedan has 20x9.5 +35 in back with a 275/30. All that was needed was a fender roll. Lowered on tein basics. Has a sliver of clearance. Rim or tire never hit the fender in 5 years
Old Nov 8, 2012 | 03:58 AM
  #6398
4DGS's Avatar
asadali91, what part of canada are you from? If you're South Western Ontario, shoot me a message I'll take care of you.
Marcus you're forgetting all those wheels with stupidly CONVEX faces that poke out of the lip edge and the spokes sweep backwards behind the mounting surface.
Big lip illusion.
Old Nov 8, 2012 | 09:41 AM
  #6399
Drew113's Avatar
Ban Hammer Expert
haha its a fraud lip!!
Old Nov 8, 2012 | 11:47 AM
  #6400
ttrank's Avatar
Grocery getter
+1
I have a 20x10 +43 with a 8mm spacer with 285/25's on the back with very little negative camber. I believe it is around -1.5 degrees.
Old Nov 8, 2012 | 12:02 PM
  #6401
JaE35's Avatar
Moderator
G35 Sedan
285/25? lol does that ride rough?
Old Nov 8, 2012 | 11:08 PM
  #6402
FlyingLumpia's Avatar
Who cares when you are running twins! LOL
Old Nov 9, 2012 | 11:31 AM
  #6403
4DGS's Avatar
Doesn't ride that rough to be honest.
Old Nov 9, 2012 | 11:35 AM
  #6404
gtrefever's Avatar
Sent you an email! You no respond fast lol. It's a pic of some wheels lmk
Old Nov 9, 2012 | 12:51 PM
  #6405
4DGS's Avatar
I did respond lol
I said I wouldn't stager tires on square widths.
wheels aren't too bad but I liked you're other options more.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
