OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Apr 25, 2013 | 08:33 PM
  #7006
MPG35fiend's Avatar
Thanks you Tunermax!! I really appreciate it!! What do you think of color matching my visors?
Old Apr 25, 2013 | 10:23 PM
  #7007
TunerMax's Avatar
G35
wow. I have no clue. assuming they could be sucessfully painted, I'd have to see it photoshopped half-decent first I think. It could go either way
Old Apr 25, 2013 | 10:40 PM
  #7008
MPG35fiend's Avatar
i honestly think it will look pretty sick! if i could get a hold of another set of JDM visors id do it in a heart beat!
Old Apr 25, 2013 | 11:08 PM
  #7009
Songle6MT's Avatar
Originally Posted by K.C
I can see that this thread is meant more for the 1st gen sedans but hopefully you guys may be able to help me out .
I'm thinking about getting some CV3's and well to be honest I'm alittle confused about the look I want as far as stance , tire sizing , offset , etc . So to start off I called around and asked about wheel options and I have decided to go with 20's.
( I WILL BE GETTING BC COILS AND A CAMBER KIT) the sizes they gave me for best fitment were
F- 20'' x 9.0 + 32
R- 20'' x 10.5 + 45
As far as the tires go
F- 245/35/20
R- 275/30/20
So my question for the wheel and tire GURU'S are...
1. Does this sound right?
2. What type of stance will I have ? i.e will it make the 4x4 look or slammed etc.
3. Does the tire fitment sound right? I ask because when I plugged the tires into a calculator there was at least a 6mm difference in height .But when I changed the width of the rear tire to a 285 the height for both wheels were the same so why would they tell me to put a 275 on instead ?
Originally Posted by SDGenius
^those rears will rub the inner suspension
I think these are going on a second gen sedan if I read correctly in the other place he posted this.
In that case they should fit without hitting the inner suspension. But yes they will hit inner suspension on 1st gen sedan.
Those tire sizes would work, or you could even go to a 285 in the back if you would like.
Old Apr 27, 2013 | 05:41 AM
  #7010
JosansG35's Avatar
Just get a lower offset rear wheel and camber that shlt. Worry about tire size once you test fit.
Old May 9, 2013 | 05:05 PM
  #7011
BazookaJoe's Avatar
245/45/19 +20 on 19x9.5 rims Rear
235/35/19 idk +45 maybe on 19x8 Rims Front
Im selling this set up btw, will be available in the market next week. Want something with a less aggressive camber
Old May 9, 2013 | 06:29 PM
  #7012
JosansG35's Avatar
Old May 9, 2013 | 06:45 PM
  #7013
TORETTO's Avatar
Old May 9, 2013 | 07:29 PM
  #7014
b-dRizZy's Avatar
WTH !! Why did you add so much camber to that rear ? smh
Old May 9, 2013 | 11:26 PM
  #7015
jookyshank's Avatar
I haz hugz to givez
Was gonna warn you to suit up...but the burning is setting in no?
Old May 10, 2013 | 12:18 AM
  #7016
MPG35fiend's Avatar
Does this fit in here?
Old May 10, 2013 | 12:29 AM
  #7017
TORETTO's Avatar
exhaust isn't low enough
Old May 10, 2013 | 12:34 AM
  #7018
JosansG35's Avatar
Since you're on bags now you should get a more aggressive setup
Were you finally able to lower the front more?
Old May 10, 2013 | 12:42 AM
  #7019
MPG35fiend's Avatar
Just posted in the sedan group in FB. Figured out its my strut. Bought a shorter BC strut from flyinglumlia..
Old May 10, 2013 | 01:35 AM
  #7020
JosansG35's Avatar
Anyone ever stanced a sedan on 17s? I kinda like the chubby tires look. Maybe the G is too big of a car.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
