OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Jun 18, 2013 | 08:36 PM
  #7036
MPG35fiend's Avatar
Originally Posted by usikan2237
would i be able to fit 19x10+ 10 and 19x11 +10 without crazy camber?
yes this can easily be done especially if youre RWD. depends Offest* on the stretch youll be running which i suggest 225/235 and 245/35 camber will be determined by what offset you run..
i am an X and my next set up will be 19x10/11 +10/20 on 235/35 and 255/35 no pull. will be shooting for -2.5 up front and -3.5 in the rear. no pull.<---- this was advised By Grant (fitment Guru)
Originally Posted by Z's G
I need a little help please. I have a 04 g35x I am running 20x9.5 front 20x10.5 rear. If I run a cooper 245 35 20 on the front do you know what I have to run on the back? I know straight up a 245 35 20, 275 30 20 would be within the 3% range for AWd but the stretched on the back is throwing me off. Thanks for the help. Would a 255 30 20 work on back?
by talking to fellow X owners about wheel and tire specs ive learned that our rolling diameter does not* have to be with in 3% rolling diameter..as long as your not ridiculously far from 3% youll be good. there is a few guys on 19x9.5/10.5 on 225/35 and 245/35 stretch with no issues for quite some time now... since those guys have been on these set ups i will be stepping into the world of WFC with my new set up and literally be Wrong Fitment due to being an AWD.
i went to "willitfit.com" and put these specs in "19x9.5/10.5 on 225/35 and 245/35" and calculated 14mm difference in diameter... so i go by that. as long as your with in 14mm from each other youll be good...
Old Jun 19, 2013 | 04:18 AM
  #7037
gtrefever's Avatar
Youll def need more than -3.5 camber in the rear winfred. For you to tuck that aired out youll need more then -5 without any body work. Comparing it to my static set up when I wws at 11+15 with a 245/35 and I had a 25mm pull.
Old Jun 19, 2013 | 08:06 AM
  #7038
MPG35fiend's Avatar
Thanks! I will at least get an 5mm pull. I can't wait to get my new set up in.
How is the stretch on 235/35 and 255/35 on 10/11?
Old Jun 19, 2013 | 08:10 AM
  #7039
MPG35fiend's Avatar
Originally Posted by JosansG35
Yes you can. I'm running 10 +0 and 11+0 and my camber is at -5 front and -4ish rear
Josan. Got a pull in the rear?
Old Jun 19, 2013 | 01:45 PM
  #7040
JosansG35's Avatar
Yeah the rear panels are pulled. But you can fit a wheel with those specs without a pull. You will just need more camber.
Old Jun 19, 2013 | 06:57 PM
  #7041
gtrefever's Avatar
Like I said you wont fit it eith just -3.5 camber. Josan fitting a 11+0 is easy when you have a big pull. He has stock fenders though. Winfred remember for every degree of camber youll gain 5mm of space. So if you run a 11+20 No pull you may need close to -7 camber or more.
Old Jun 19, 2013 | 08:01 PM
  #7042
MPG35fiend's Avatar
ill get me a pull then!!! thanks guys.... <3 you.
Old Jun 19, 2013 | 08:03 PM
  #7043
MPG35fiend's Avatar
how much of a pull?
are you sure? im running a 10.5+22 -2.5 camber.
Old Jun 19, 2013 | 08:41 PM
  #7044
CandlestickPark's Avatar
ill Sedan
Project Definition photo and video shoot.
Teaser photo
Video (be sure to watch in HD and full screen)
Old Jun 20, 2013 | 02:55 AM
  #7045
jookyshank's Avatar
I haz hugz to givez
Always amazing Marcus
Old Jun 20, 2013 | 04:02 AM
  #7046
v35sedan91's Avatar
just got my rims
xxr 531's 19x8.5+15 235/35 front and 19x10+20 rear 245/35
gonna be resprayed gunmetal soon and im also trying to figure out how to get the front more flush,maybe less camber or a small spacer maybe?any ideas?
Old Jun 20, 2013 | 10:57 AM
  #7047
gtrefever's Avatar
Your new set up will be 8mm more aggressive. Are you st 2.5 drive height or aired out? When I ran 11 +9 my wheels tucked perfeftly jnto the fender. So you actually may be fine.
Old Jun 20, 2013 | 02:02 PM
  #7048
Lenox102's Avatar
So this is no where near as flush as you guys but looking for opinions.
Looking to going with 19's. probably 8.5/9.5 or 9.5 all around. 8.5's are +32. 9.5's can be +24 or +35.
Looking at going with 350z h&r springs. What tire size would you guys recommend? And will my fenders need rolled?
Old Sep 13, 2013 | 09:58 AM
  #7049
NFSP G35's Avatar
? = 2B || !2B
So, for starters, I'm by no means an expert on stretching tires... that's why I'm asking you guys that are.
Guy at work has some 18x8's and he's thinking about going with either 225/40 or 215/40... how much of a stretch is the 215? Pics would be very nice.
Old Sep 17, 2013 | 02:14 AM
  #7050
JosansG35's Avatar
Baby stretch.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
