350Z engine cover fit a g35 engine?
Old Oct 18, 2009 | 09:37 PM
G35Papa's Avatar
If you have an 2003.0, you will need to cut the front of the cover to clear the clutch fan that the 2003.0 sedans run. The OEM snorkel should hide the cutting you'd have to do if you keep it on.
Since you have a 2004, you are fine but just wanted to point that out for others coming across this thread.
Old Oct 18, 2009 | 10:09 PM
Nemo7's Avatar
ok thanks alottt what difference will i have getting the 1/2 than the 5/16 spacer?
Old Oct 18, 2009 | 11:44 PM
NjMatteSedan's Avatar
more top end power with the 1/2 vs more low and midrange power with the 5/16 which is the most useful hp
vmcarbuyer
Oct 12, 2019 12:42 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
LoSt180
Jul 15, 2015 08:31 AM
