The "Look what I made/installed/modified today" thread.
May 4, 2011 | 10:39 PM
  #796
^^^ That would be pretty sweet if they were Brembos or Akebono's... hmmm... ideas, ideas!
Reply 0
May 4, 2011 | 10:58 PM
  #797
it definitely would, i'm just not there yet, so i have to work with what i have
Reply 0
May 5, 2011 | 12:41 AM
  #798
painting OEM calipers black when you have after market wheels makes perfect sense to me... they look awkward and negate nice wheels (black changes that)... but painting them a flashy color to draw attention to them is a step in the wrong direction imo.
When I first got CE28Ns the calipers were an eye sore - I painted them black and it really allowed the eye to overlook them... I dont think showing off the OEM brakes makes sense unless they are Brembo or Akebono (not the Altima ones).
Just my .02 (since you asked).
Reply 0
May 5, 2011 | 12:44 AM
  #799
it makes sense, and i appreciate your input...i was actually liking the way they looked when i laid the black primer down...i had just thought of trying something different, but as i finished i was questioning myself if i really liked it or not
Reply 0
May 8, 2011 | 05:59 PM
  #800
Reply 0
May 11, 2011 | 09:46 PM
  #801
Just got done installing the following:
SPL Compression Rod Bushings
SPL V3 A-Arms
2x Nissan Hub Assemblies
All I can say is WOW! I didn't remember what driving my car with functional compression rod bushings felt like, The steering is tighter and the front end overall feels so much better!
Old busted bushing:
New SPL Solid bushing:
Installed:
New hub with Ichiba extended studs installed (running 10mm spacers)
I'll be installing the following in 2 weekends:
Tein Inner Tie Rods
Whiteline Front LCA bushings
Whiteline Front LCA shock bushings
Reply 0
May 11, 2011 | 09:47 PM
  #802
Nice Grant, those SPL bushings are on my future mod list.
Reply 0
May 11, 2011 | 09:58 PM
  #803
Quote: Nice Grant, those SPL bushings are on my future mod list.
Be prepared for a STIFF front end and steering feel. I've heard they make noise after a while but we'll see. I don't mind the stiffness or noise as i'm just excited for my car to drive properly again. And of course there will be more noise and vibration with solid bushings.
If you want to retain a little bit of comfort i'd go with the Whiteline or Energy bushings.
Reply 0
May 11, 2011 | 10:01 PM
  #804
I bet ya thats what my cr bushings look like. My spls are on order. I finally decided if i went with any else id be replacing again since i like to slam and raise my ish
Reply 0
May 11, 2011 | 10:02 PM
  #805
I was thinking of a full Whiteline bushing overhaul, getting up near 100k.
Reply 0
May 11, 2011 | 10:06 PM
  #806
Quote: I bet ya thats what my cr bushings look like. My spls are on order. I finally decided if i went with any else id be replacing again since i like to slam and raise my ish
Same reason I got the SPL's. CR bushings aren't hard to replace, but i'd rather just do it once and be done.
Weird thing is, the right side bushing was blown but I replaced the entire arm about 20k miles ago and the left side with 86k miles on it was still good! Haha
Reply 0
May 11, 2011 | 11:37 PM
  #807
It's time I replaced my hub assemblies as well. I'll prob order them next week. Those SPL bushings look futuristic
Reply 0
May 11, 2011 | 11:44 PM
  #808
sways and whiteline bushings coming soon to my car....
Reply 0
May 12, 2011 | 09:07 AM
  #809
Quote: I was thinking of a full Whiteline bushing overhaul, getting up near 100k.
I just did the Energy Suspension bushing kit.
All lower/upper control arm bushings front including the compression rod bushing and all the rear lower/upper control arm bushings
Car def. feels much more controlled ride /handling wise.
Reply 0
May 12, 2011 | 06:55 PM
  #810
no pictures yet but i finally figure out how to relocate my fuel and evap lines. so i did that today. took about 10 minutes to do
Reply 0
