The "Look what I made/installed/modified today" thread.
Jun 7, 2011 | 03:03 PM
  #991
I dunno seemed pretty serious about it...
Reply 0
Jun 7, 2011 | 03:51 PM
  #992
Quote: i have, just my attempt at humor and laziness bundled into 1. teh intranetz doesn't capture the true essence of my dry sense of humor
Now that's funny!
Reply 0
Jun 7, 2011 | 07:03 PM
  #993
Quote: I don't know about that
My guess is they are used to either swap out fluid (open bleeders and let the fluid drip out) or the calipers are used on other cars (besides Nissan). You can flip the caliper to the right side of the rotor for other cars.
Hey Papa WTF??
I think you are onto something with the calipers. I don't think you would ever bleed from the bottom. Kinda defeats the purpose as all the fluid would rush out and create air pockets in the top.
Reply 0
Jun 7, 2011 | 07:15 PM
  #994
Quote: Correct. From the Wilwood install manual:
"To properly bleed the brake system, begin with the caliper farthest from the master cylinder. Bleed the outboard bleed screw first, then
the inboard. Repeat the procedure until all calipers in the system are bled, ending with the caliper closest to the master cylinder. If the
caliper is fitted with bleed screws on four corners, make sure the bottom bleed screws are tight. Only bleed from the top bleed screws.
Here are the links to the manuals Tim:
Fronts (w/14" rotors) - http://wilwood.com/PDF/DataSheets/ds547.pdf
Rears (for later) - http://wilwood.com/PDF/DataSheets/ds546.pdf
Thanks!! I downloaded the front manual from their website Sunday morning before we started the install. I missed the part about bleeding. Good news is that Summit Racing hooked me up with a pack of 4 bleeders overnighted and the brakes are up and running.
Reply 0
Jun 7, 2011 | 07:56 PM
  #995
pretty sure WW has bleeders on both ends to cut costs in making side specific calipers
Reply 0
Jun 7, 2011 | 08:07 PM
  #996
Probably. My fronts don't and actually have a little arrow on them to make sure you mount them correctly. So do the rotors.
Reply 0
Jun 7, 2011 | 08:13 PM
  #997
yeah, i know. once they put together the kit, they etch them. a lot cheaper than a whole extra cast. WW make's their calipers very custom kit friendly.
Reply 0
Jun 7, 2011 | 11:34 PM
  #998
Stance looks nice Tim!
Congrats again on the BBK. Are you running 13" rotors?
Reply 0
Jun 8, 2011 | 01:45 AM
  #999
14" up front sir.
Reply 0
Jun 8, 2011 | 01:51 AM
  #1000
Your wheels really dwarf the 14" rotor. Look fantastic though! I can only run up to 13" and a little rotor with my wheels (18" step lip ftl)
Reply 0
Jun 8, 2011 | 06:27 AM
  #1001
Thanks man. The design of my wheels has a lot of advantages such as looking bigger than they are and leaving a lot of clearance for a BBK. While I understand the Wilwood are a low profile BBK I still have an inch of clearance between the back of the spokes and the caliper. But I didn't necessarily want them making the rotor look smaller.
Here's a pic we took during the install showing the difference in rotor sizes. I would have taken more but Nando had to get back to Houston when we were finished so we were in a hurry to get the job done.
Reply 0
Jun 8, 2011 | 09:41 AM
  #1002
Such a big difference!
Reply 0
Jun 8, 2011 | 09:49 AM
  #1003
Looks good tim. Now u just need to find a deal on the rears. Its crazy how light the ww calipers are compared to stock
Reply 0
Jun 8, 2011 | 10:48 AM
  #1004
I'd love to be able to afford a BBK for the front at the very least.
Reply 0
Jun 8, 2011 | 10:50 AM
  #1005
hey blue dream that's an AWESOME pick up!
good thing they have that portion between the rotor hat and contact patch painted black. I remember I had paint it myself because it was starting to rust. It's kinda sad Wilwood uses the same exact caliper for both the 13 and 14 inch kits, just a differet bracket and bigger rotors.
Reply 0
