threw some 20'son my sedan
Old Oct 20, 2010 | 02:33 PM
35grams's Avatar
i went to the axis wheel sale at there headquarters last Sunday in sante fe springs near the 5 frw and got some 20' wheels for 75 bucks a wheel my problem is the rear is 20.10 so i wrapped the rear with 2553520 tires and it rubes so bad you dont even know so im waiting for my 2453020 to come to see if that helps
Old Oct 20, 2010 | 02:35 PM
geesteezd's Avatar
Good deal.. Which model?
Old Oct 20, 2010 | 02:58 PM
EnviedG35's Avatar
A 255 on a 10" wide wheel should not be rubbing. The offsets on the wheels must be really low and not made for a sedan that isnt lowered a good bit and running more neg camber.
Old Oct 20, 2010 | 03:03 PM
socialconflicts's Avatar
if you run some neg camber it should fix it. but like he said should not be rubbing unless the offset is low.
Old Oct 20, 2010 | 03:27 PM
CandlestickPark's Avatar
ill Sedan
Please post up some pics. How low are you? How much negative camber are you running? Are your fenders rolled flat? Offset of the wheels?
Old Oct 20, 2010 | 03:43 PM
4DGS's Avatar
Most axis offsets are 10 with a +20
If he's even slightly low (1") he's going to rub as a 25mm with no camber is a straight poke, if he's on springs he's probably banging the **** out of the fenders from not having stiff dampening.
GR6RR's Avatar
Roll them fenders, you should be aighht! yO!
Old Oct 20, 2010 | 03:54 PM
SN00P's Avatar
CLUB MODERATOR
ROLL them fenders !! you your car will be on point !
Old Oct 20, 2010 | 04:16 PM
thescreensavers's Avatar
Mr.202?
75 a wheel!! what post pics.
Old Oct 20, 2010 | 04:28 PM
35grams's Avatar
here ya go im lowered 2' front and 1.9 rear with tein s tek and tokiko shocks
Old Oct 20, 2010 | 04:49 PM
NNOCENT's Avatar
Looks good.
$75 per wheel, you practicall STOLE them.
They are not my taste, but I think they look really good, and different from the norm!
Old Oct 20, 2010 | 05:07 PM
GR6RR's Avatar
they sure are different... =X
Maybe a different color would look much better, but its not bad for 75 bucks a wheel.
And you should be good to go after a fender roll..
Old Oct 20, 2010 | 06:19 PM
Blue Dream's Avatar
I drove ttrank's car solo
You better address your fenders very soon or you are going to destroy them. You've got some work to do to make them fit properly.
However, it's hard to beat new wheels for $300.
Old Oct 20, 2010 | 08:02 PM
JaE35's Avatar
Moderator
G35 Sedan
20's ate my suspension alive after about a year, keep a close watch
Old Oct 20, 2010 | 08:09 PM
kennymo's Avatar
Sell me the tires
