snoops new engine bay pictures :-)
Old Nov 4, 2010 | 09:44 PM
  #31
bigc's Avatar
Wings Nation
nah, no heat issues from removing those liners. if anything, you'll hear slightly more engine noise.
with regard to the filler, you may be right about it being a screw. i removed mine a long time ago so my memory may be off. if you want to retain the filler, though, i'd replace that clip/screw with a pop rivet so you can remove it quickly.
the windshield wiper reservoir is below the filler. you can put a piece of tape over the mouth if you're concerned about anything falling in there.
Old Nov 4, 2010 | 10:13 PM
  #32
CandlestickPark's Avatar
ill Sedan
+1 on everything bigc said. He knows what he's talking about.
Old Nov 4, 2010 | 11:13 PM
  #33
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by g35snoop
if i take the cover off the hood and the fabric from behind the engine it wont cause any heat issues ??? i DD my car but i don't want to cause harm if i don't need to .....
That blanket isn't to keep heat off your hood. Heat shields would do a better job of that.
It's there for two reasons
First: If the engine catches on fire, it's a fire retardant that's supposed to help control it... in reality, I've seen plenty of cars burn to the ground and that stupid blanket did nothing.
There's so many flammable things under the hood that it doesn't cover, I don't even know why they bother
Second: It provides a very small amount of sound deadening. You may not even notice the difference though.
^+1,000,000!!! I'm scared if I ever saw BigChris' engine bay in person, I would have to clean the drool off it!
Old Nov 5, 2010 | 09:09 AM
  #34
SN00P's Avatar
CLUB MODERATOR
ok thanks i guess ill take that stuff off well at least the one under the hood for now :-) thanks bigC for the help
im going to try and tackle everything marcus put on the list today
Old Nov 5, 2010 | 09:25 AM
  #35
Swivel's Avatar
Moderator
Took my underhood liner off recently to make a tiny bit of room for my strut bar. Don't notice any difference re: noise.
Old Nov 5, 2010 | 11:06 AM
  #36
SN00P's Avatar
CLUB MODERATOR
^^ thanks :-) im definitely going to do it
pigpen infiniti
Aug 16, 2015 09:07 PM
joedaddy1
Jul 28, 2015 02:58 PM
