04X Sedan S2K Headlight Retrofit
Fyi, the mini bixenon will fit up top in the sedan lights. I put them in viveks headlights. The only issue with putting the s2k up top and if you decide to put a bixenon down low for the hi/fog is that with the wiring going thru the bcm, is that if you using the power from the fog for the low it will kick off when you hit the high beam. good luck cant wait to see finished pics
The only way the minis would be plug and play would be that it would go in the lower location. All you would have to do is add a shroud to the projector. There isnt a projector that is able to go into the top location without cutting. The shroud will have to be cut everytime for the lens to close into the housings. There isnt a easy way to make quads on sedan lights as there is on the coupes.
U mounted the s2k kinda of far back. Can you still put the cap on the back of the housing. Its funny you say that a quad retro may look goofy when everyone seems to want one. Looks good so far. Your right about the s2k bein one of the best. Its what I have up top along with a fx35 down low. Beebo now has Gsedans setup that I did with the s2k up top and tl down low.
Worked on the lights a little today. Had to do some serious trimming on the Apollo's but I think they're gonna work. Here's a few pics with the shroud in place. The bezel will require some trimming too, I'll post up those pics hopefully tomorrow when I can work on them a bit more. It's effin freezing out in my garage lol!
my setup is holding up pretty good so far in the michigan weather parking out in the cold weather. nothing frozen, bixenon motor works good even though i dont use it much.
Ya, I edited my post after I read it didn't make any sense. I was referring to the outer lens getting covered in snow and ice because hid's run so much cooler than halogens, there's not enough heat to keep the snow and ice melted off the lens.
