Don E's G35 Sedan in progress
Old Jan 24, 2011 | 12:41 AM
r1forever80's Avatar
General uhp
Old Jan 24, 2011 | 12:57 AM
toymachine2009's Avatar
Offsets are perfect. What tire sizes are you planning. You'll need to roll your fenders really flat front and rear. Do you have a camber kit in the rear, you'll likely need to dial in your camber out back.
How low do you plan to drop it?
how come not front? Is the natural camber up front fine? how many negative degrees up front would natural camber be on slammed ride?
Old Jan 24, 2011 | 12:59 AM
Wannabe6MT's Avatar
-MN G Crew-
Can't wait to see those wheels on the car!
Old Jan 24, 2011 | 11:06 AM
DivZero's Avatar
Welcome to the club!
Old Jan 24, 2011 | 11:24 AM
CandlestickPark's Avatar
ill Sedan
I didn't recommend the front because the a-arms are pricey and you can get away with not needing them. I haven't gotten an alignment yet but I'm dropped ~3.5" up front and I suspect I'm running between 3 and 4 degrees of camber or so. That is enough to clear those widths/offsets and tire sizes.
Old Jan 24, 2011 | 12:24 PM
don e's Avatar
thank you
Old Jan 24, 2011 | 01:05 PM
How fast does -3 chew your tires up front tho.
Old Jan 24, 2011 | 02:58 PM
NFSP G35's Avatar
? = 2B || !2B
I subscribe to all sedan progress threads
Old Jan 24, 2011 | 03:13 PM
ill Sedan
My fronts usually lasted twice as long as my rears. I would go through my rears every 9 months or so and my fronts every year and a half or so, maybe a little less. I was driving my car about 15K-20K per year when I was daily driving it.
Old Jan 24, 2011 | 03:40 PM
holy crap your fronts lasted a long time with about -3 degrees of negative camber. Thats what I like to hear cause I wanna go lower and I only have rear camber kit and toe bolt nothing up front..
Old Jan 24, 2011 | 03:43 PM
ill Sedan
^Yup I got almost 30K out of my fronts (Falken FK452s) when I was running -2.75 degrees of camber. They were very bald on the inner part of the tire when I swapped them out.
Old Jan 24, 2011 | 04:14 PM
yea i bet.. Couldnt you have switched the tire around on the wheel tho?
Also yea when you get that inner camber wear you start getting that cupping and you hear a thump thump thump very lightly. Happened to my rear tires.
Old Jan 24, 2011 | 04:18 PM
don e's Avatar
Need advice on tires guys... front wheels 19x9.5 12offset 225/25 or 235/35 tire brand is Forceum gettin a deal on them thats why.
Old Jan 24, 2011 | 05:07 PM
don e's Avatar
Old Jan 24, 2011 | 05:08 PM
  #30
ill Sedan
I have no clue if Forceums (never heard of them) run large, true or small. Anyone every stretched these before? TycoRC did 235 up front and his fronts aren't even pinched all the way flat and he's fine. His Nexens run small though so its more like a 225.
