SN00P's FULL custom trunk :)
Nice box, but no..
1 cube internal airspace? In most cases, that'll leave what...6-.7 for a 12? Yeah..not happening.
Your average 12 would need around 1.5 AFTER sub displacement to do it's thing. That's get low into the 30's like subs are suppose to..not fall flat on it's face around 50hz like most setups are since subs are stuffed into smaller enclosures then the shipping container they shipped in.
You'd get more output and dig deeper making these for ported 8's.
I see cancellation issues here.
If you guys are concerned about trunk space, please look into infinite baffle
from Alpines owners manual on the new type R 12's
displacement is .10 ft3 take that away from there recommend sealed box size of .55 ft3 to 1.0 ft3 - puts this box ideal for there specs.
a ported box will always outperform a seal box, but that is why you port a box, to build a DB gain at desired FQ, a ported box is aslo bigger,
the idea of these boxes are to give a good bass responce without givingup much room, this wont be for everyone, but for those who want more bass and still need your trunk this is your solution.
The ships takin fire captain. Return fire matey, return fire !
So what would be the best way to protect these speakers from damage? Seems like they take up marginally less space than a box.
On the other hand are these boxes bottoming out? Or is terr a bunch f sound deadening needed
Looks good...woulda been better if enclosures were a bit larger and feeding them min 750w, nonetheless it looks good.
+1 for IB though. Till this day I still wish I woulda picked up a pair of 18" Image Dynamics drivers.
