I finished my headlight retrofit!!!!!!!!!
Old Jun 12, 2012 | 05:45 PM
  #31
xmysterx2000's Avatar
Originally Posted by G35Papa
+1 nice work, they came out great. Projectors really update the front end of these cars so much
Thank you! It sure does. it almost looks like a whole different car haha. I had someone the other day ask me what kind of car it was. (needless to say I dont think he was too familiar with the G's). Still makes it looks much different and NICER!!
Old Jun 15, 2012 | 01:26 PM
  #32
Mr. Samster's Avatar
your headlight looks awesome!!
I was wondering for the shrouds on the morimotos did you glue them with the hub centric ring and then glue them onto the projector itself or did you glue the hub centric onto the shrouds and just slide it onto the projector tightly? Ive read the TRS DIY on how to install the shrouds and that is what they suggested, but mines keep falling off or the hub centric ring gets melted and it falls off.
Old Jun 15, 2012 | 01:38 PM
  #33
I did not even use the hub centric ring. I glued the shrouds onto the bracket I made for the projectors (up top on the minimoir's). In the bottom position I glued them right to the projector beccause they would not fit all the way around the projector without major modification.
Old Jun 15, 2012 | 02:13 PM
  #34
gotcha Thanks!! I guess im going to glue them now. And hopefully that does it.
Old Jun 15, 2012 | 04:18 PM
  #35
What kind of glue are you going to use? I used the UV6800. You can use the regular E6000 I think it is. The only reason I used the UV6800 is just in case the sun does something to the other glue this one has the UV protection. So I just glued them with this stuff. It glues anything together.
Old Jun 15, 2012 | 05:39 PM
  #36
i see. you can buy that glue at home depot?
Old Jun 15, 2012 | 05:42 PM
  #37
Yes im sure you can. I bought mine at a plastics store but almost certain you can get it at home depot.
Old Jun 15, 2012 | 07:34 PM
  #38
JaE35's Avatar
Moderator
G35 Sedan
Any recommendation on an hid conversion kit? I need one to wire up the ebay lights i have
Old Jun 15, 2012 | 07:40 PM
  #39
VMRWheels's Avatar
Nice work! The project came out looking pretty good.
Old Jun 15, 2012 | 07:43 PM
  #40
I cant find the link, but I saw some HID conversion kits that someone posted going for $35. I would just go with any 35W ballast set up. I bought some that someone was selling for $45 off craigslist. And I only needed one set because I was able to use the Stock HID system my lights already had.
Old Jun 15, 2012 | 07:44 PM
  #41
Thank you!! I put all my blood sweat and tears into those lights!!!!
Old Jun 15, 2012 | 11:53 PM
  #42
CandlestickPark's Avatar
ill Sedan
Came out great man, nice work.
Are the lower projectors pointed up at a higher angle than the uppers?
Old Jun 16, 2012 | 12:32 AM
  #43
Thanks!! I do think that they are pointing at a different angle.
Old Jun 16, 2012 | 12:34 PM
  #44
kingnba6's Avatar
looks nice! light output must be great
Old Jun 16, 2012 | 01:05 PM
  #45
Thank!! I will be getting a light output pic when I can.
