View Poll Results: Which way to fix it??
Replace spark plugs & coils to see if it fixes issues
0%
other down stream issues known that could fix
0%
Voters: 0. You may not vote on this poll
04 g35 sedan 3.5
Old Oct 22, 2024 | 12:42 PM
timb450!'s Avatar
fun
04 g35 sedan 3.5
So I have the following codes p0030,p0031,p0037,p0051,p0057. also have issues with it throwing vvt solenoid. but issue at hand is i have it running but when i put it in gear goes nowhere. matches rpm but no motion. could it be a tcm issue or shift cable issue.
Active code;
p0030- leading misfire issue ( heating element - downstream o2 sensor behind the cats ( debating replacing all spark plugs & coils)
p0031- ho2s1 heater bank #1
p0037- heated o2 sensor bank #1
p0051- ho2s1 heater bank #2 ( faulty sensor)
P0057- Ho2s1 (heater bank #2) - pcm reading issues with voltage that doesnt fall within parameters
timb450!
Media Share G35 Sedan V35
Oct 22, 2024 12:41 PM
Jbutku4
Mar 29, 2019 03:29 PM
Rawrster
Sep 17, 2016 06:03 AM
xsl_will
Mar 24, 2014 01:36 PM
dragonv
Mar 14, 2013 11:31 PM
