NEED HELP...19" wheels...225/245 or 245/275???
Old Jan 27, 2009 | 02:57 PM
T0Onyce's Avatar
All ’07-‘08 G35 Sedan owners, I need your assistance! I am getting 19” wheels and DO NOT plan on lowering my car. The main dilemma is the wheelwell gap. I do not want anymore of a gap than what my stock wheels/tires already create. Currently, my stock tires are 225/50/18 (front) and 245/45/18 (rear).
So I have two options for tires:
1) 225/45/19 and 245/40/19
2) 245/40/19 and 275/35/19
With option #1, I keep the same widths but the diameters of the tires are a few millimeters larger. With option #2, the widths are wider but the diameters are a few millimeters smaller.
My question is will a few millimeters make a noticeable difference in regards to the wheelwell gap? If not, then I will probably go with a 245/275 combo because I like that wider, beefy look. Can you please provide comments and/or photos of your wheelwell gaps? Photos would actually be very helpful, preferably with the tire combos mentioned above.
Thank you in advance and have a (T0O)nyce day!
Old Jan 27, 2009 | 04:38 PM
boss81's Avatar
I just got 19s and I went with 245/35 in the front and 275/35 in the back. I didn't plan on lowering it either, but after I saw the gap I wanted to. Here ya go.....
Old Jan 27, 2009 | 04:40 PM
sheplex02's Avatar
do like boss81..
but both of you get tein comforts..(as long as u still want soft ride but lower)
Old Jan 27, 2009 | 04:43 PM
boss81's Avatar
Thanks man, I'll look at those. (sorry to hijack)
Old Jan 27, 2009 | 05:49 PM
T0Onyce's Avatar
Boss81, good ish man! This is what I was looking for! What is the width of your front and back wheels?
Also, if you were not planning on dropping your car, why did you choose 245/35 for the front? That tire measures 655 mm in diameter, while our stock tire measures 683 mm. The diameter for a 245/40 tire is 679 mm, which is much closer to stock diameter.
I've been using this online wheel/tire calculator:
http://www.bigcustomwheels.com/info_specs.jsp
I wonder how accurate these things are?
Old Jan 27, 2009 | 06:53 PM
boss81's Avatar
The front wheels are 19 x 8.5 and the rear wheels are 19 x 10.5. I was considering dropping it even when I had the stockers, but I thought the 19s would make it look better and I would like it without a drop. I was wrong and I decided to drop it. Here is the pic of the side of the car......
Old Jan 27, 2009 | 07:18 PM
T0Onyce's Avatar
Thnx for the pics! I like the look of your car with stock springs, you didn't? I am content with how the rear sits on stock springs because the gap is not that bad. My problem is with the front wheelwell! Haa! Don't know why Infiniti chose to do that???
Old Jan 27, 2009 | 09:04 PM
boss81's Avatar
Thanks for the compliment! I am the same way, the rear is good, but the front is bad.
Old Jan 27, 2009 | 09:42 PM
AesonVirus's Avatar
I agree. I hate the front gap. I went with 245-40-19's and still have that front gap.
Matter of time before a drop is done... just not today.
Old Jan 27, 2009 | 10:40 PM
johnnyzee's Avatar
if you try 245-45-19, you might get away with less wheel gap.
Old Feb 5, 2009 | 02:11 PM
T0Onyce's Avatar
Your car is an "X", right? They have a higher stock ride height though, so you must take that into consideration. Nice wheels--perfect offsets! Any pics from behind? I want to see how wide your tires look from back there.
knightro g35
Aug 27, 2015 09:31 PM
G35sedan03
Aug 29, 2014 07:12 PM
98intrigue
Picture Share
16
May 12, 2009 04:34 PM
Saridi
Apr 1, 2004 01:16 AM
