Request: Post your Side profiles; OE & dropped
I'd like to put up a reference page that shows side profile shots of stock Sport, Journey and X's at stock height as well as dropped. (Equipped with all OEM equipment, down to the tires)
For those that have photos, will you please share them and provide the following info as well?
- Spring brand/model
- Height from the ground to the edge of the fender line
Ideally, the angle of the shot should be similar to the one below. High resolution images are preferred so i can trim them down and normalize the size of each vehicle presented in the final page.
![](https://g35driver.com/forums/members/soundmike-albums-g35-sedans-gen-2-picture4394-g35-011.jpg)
Thanks, all!
Thanks, all!
Here's mine. Don't have good pictures of the car facing the other direction, but you can just flip the pictures if you'd like.
I usually measure height from the center of the rim to the edge of the fender/wheel well. This equalizes all other parameters like wheel and tire size, tire pressure, etc. and IMO is the most accurate measure of just the drop alone. In both pictures, the car had about 1/4 tank of gas. I've found adding a full tank of gas can lower the front about another 1/8" and the rear another 1/4" or so. Also, heights from left to right may not be exactly identical. Depending on how I measured, it varied from 0" to 1/4" difference in height btw left and right.
Stock height with M45 19s, 245-40-19 tires, +20mm spacers x 4
Center of rim to edge of fender - Front: 15 5/8" Rear: 15 3/8"
Floor to edge of fender - Front: 28 1/4" Rear: 27 3/4"
![](http://img72.imageshack.us/img72/4188/g35stockheightn.jpg)
Lowered with Eibach pro-kit springs, SPC/Eibach rear camber kit corrected to -1 degree, M45 19s, +20mm spacers, front lip and FI exhaust
Center of rim to edge of fender - Front: 14 1/8" Rear: 14 1/8"
Floor to edge of fender - Front: 26 3/4" Rear: 26 3/4"
![](http://img377.imageshack.us/img377/3741/afterrq9.jpg)
